Airbag kneepad retrofit
Yes a couple of screws in the centre console area. From memory I had to modify the centre console panel a little as something was fouling the larger kneepad. Its supported by screws in than alu bracket on either end. (drilled two holes each side into the dash metal panel but this is not visible even if going back to original).
Neil
Neil
