Shifter links bushings fail and replacement
It's a weird feeling when you try to engage the fifth gear and you find yourself in neutral with a failed shifter...
Here was why :
I unfited the whole thing and it looked nasty :
As I was in a hurry to repair and go, I used a 3.2 G50 Ball Socket, as the 3.2 ball is the same 18+ mm as the 964's
I had to trim and shorten it, so it would fit in the link-tube (it's too long and too wide)
I am happy with the result, since I could get back on the road with a 12€ part instead of a 123 oem one.
https://www.rosepassion.com/en/cat/p...-socket/P15799
vs
https://www.rosepassion.com/en/cat/p...de-tube/P43367
Is there any alternative source for the correct 964 link tube bushings ?
thanks
Anyway, I'll have to go back there and fit a new boot around that linkage.
Here was why :
vs
thanks
Yep, these bushings disintegrate into dust over time. The 928 bushing is a direct replacement. A bit fiddly to pop them in (boiling them helps soften them up for an easier install).
part number 928.116.145.03
An even better solution is to modify to spherical rod ends / heim joints. Sealed with grease and a rubber boot, that would last forever and remove some flex in the linkage.
I found the bushes simple to install when using a bench vise and a socket able to fit inside the empty cup.
I had this issue years ago when the trans was stuck in 4th and the rod fell off. Oops.
