Orientation for power steering cam shaft seal?
I replaced the o-ring (#5) and shaft sealing ring (#6) on the power steering pump bracket (the big aluminum housing that covers the belt and pulleys). I looked at PET and oriented the shaft seal (part #6 below) such that the flat part faces out (kind of like the rear main seal).
I found the picture below on pelican parts and I installed my seal the opposite of this. Is the seal inserted properly in the picture below or is it backwards? I'm hoping this picture is backwards...
