Rennlist - Porsche Discussion Forums (https://rennlist.com/forums/)
-   964 Forum (https://rennlist.com/forums/964-forum-59/)
-   -   C2 Suspension refresh - RS ride height (https://rennlist.com/forums/964-forum/1132478-c2-suspension-refresh-rs-ride-height.html)
Dtronics 03-06-2019 08:49 PM
Iíve read through a bunch of the older threads on this topic but wanted to see if thereís any updated information.
I want to lower a C2 to RS ride height using KW V3ís. Iíve used V3ís on my last couple of cars and I like them. Iím curious to hear what additional recommendations there are for ďwhile weíre atĒ updates like bump steer kit, end links, spring plates, etc. This is a weekend street car thatís not used on the track so Iím not looking for overkill but I want to do it the right way. Any recommended setups would be helpful.
Spyerx 03-06-2019 09:22 PM
Just do the shocks and make sure your bushings are all fresh.
Dtronics 03-06-2019 09:49 PM
Thanks. I didnít mention that itís a low mile car (under 50k). I think that im going to refresh with the Elephant racing sport rubber bushings.
I was also going to do the Elephant bump steer kit and tarett drop links at the recommendation of the shop. Do you think I should skip this?
Spyerx 03-06-2019 09:55 PM
Drop links are good as they will let you get the balance right with no preload. Bump steer kit is good depending on ride height.
For a street focused car i wouldnt do too much more.
Dtronics 03-06-2019 10:00 PM
Thanks again. I might go slightly lower than RS height but thatís the general look/ height I want. I donít want to throw money away but I also donít want to take the cheap way out doing it. It seems like the Elephant rubber bushings have great feedback for the street.
Peteinjp 03-07-2019 09:07 AM
The bump kit also does away with the rubber bushings in the steering arms- so thats 2 birds with one stone if your going to rs heights. Wouldn’t bother with the bushings or drop links unless there shot- which is unlikely at your mileage as they hold up pretty well. If your pushing the car the rs sway bars are a great addition.
pete
Lorenzoh 03-07-2019 12:35 PM
I have under 50k miles on mine and went with HR/Bilstien setup lowered almost as far as the setup would allow. Iím getting some pretty severe bump steer and itís my understanding that the elephant racing bump steer correction kit should take care of this. I just have not gotten around to doing it yet. Iíd suggest doing it ď while youíre in there ď.
Dtronics 03-07-2019 12:54 PM
pete
Originally Posted by Lorenzoh (Post 15686695)
I have under 50k miles on mine and went with HR/Bilstien setup lowered almost as far as the setup would allow. I’m getting some pretty severe bump steer and it’s my understanding that the elephant racing bump steer correction kit should take care of this. I just have not gotten around to doing it yet. I’d suggest doing it “ while you’re in there “.
Thanks guys. I appreciate the replies and additional input. I like the RS sway bar idea. Maybe I'll hold off the replacing all the bushings because they're in good shape. I was thinking about replacing them because I read a lot of good stuff about the Elephant sport rubber bushings but I can do that later. Maybe I'll do the following:
-KW V3's
-Elephant racing bump steer correction kit
-RS Sway Bars
-I think I'm going to do the RUF strut brace too
It's also worth mentioning is anyone is looking at coilovers, KW has a rebate of $150 for V1's and $350 for V3's from 3/1-5/31.
tonymission 03-07-2019 12:59 PM
Subscribed in here Dtronics.... looks like a good list there.
Dtronics 03-07-2019 01:07 PM
Thanks, Tony. Hopefully you can get some ideas in here for your new car.
911Jetta 03-08-2019 10:59 AM
Glad this came up.
The bump kit also does away with the rubber bushings in the steering arms- so thats 2 birds with one stone if your going to rs heights. Wouldnít bother with the bushings or drop links unless there shot- which is unlikely at your mileage as they hold up pretty well. If your pushing the car the rs sway bars are a great addition.
+1
Regardless of ride height, the Elephant kit seems like a no brainer... Not much more that Porsche replacement parts, yet a definite upgrade in design and performance.
https://www.elephantracing.com/porsc...e-rods-for-964
Steering rack brace?
Also Rennline is offering an upgrade to the factory ball joints. Looks like a nice area to get a little more performance, without cost or performance negatives. (no affiliation...)
Rennline's New High Density Line of Bushings and Mounts
The all new Rennline High Density collection provides enthusiasts a perfect compromise between solid bushings and standard, run of the mill OE replacements. These bushings, mounts, shifters and more will provide a more connected and planted feeling between you, your Porsche, and the road. Sport durometer pieces offer an increase in stiffness of approximately 25% over factory replacements, which is enough to significantly improve performance without added road noise and vibrations associated with solid mounts.
http://www.rennline.com/newssection.asp?dept=1185
What are people's thoughts?
Dtronics 03-08-2019 10:40 PM
I reached out to Elephant Racing and they recommended the following for a street car at RS height:
-Front tie rod kit with adjustable bump steer
-Sway Bar Front "RS" Version 5 Way Adjustable
-Sway Bar rear "RS" Version 3 Way Adjustable
-964 Euro RS swaybar bushing Front/ Rear
-Drop link set, adjustable length and spherical bearing for front with boots
-Drop link set, adjustable length spherical bearing for rear with boots
They recommended Von coilovers which is what I expected. I’ve had V3’s and a couple cars and I like all the adjustments, quality, and comfort for the street. I’ve also used H&R coilovers but I prefer the KW’s.
I’ve never used anything from Elephant Racing before but I have to say they have excellent customer service. This is the second time I’ve reached out to them and they’re always very helpful talking through options.
Spyerx 03-09-2019 09:52 AM
Up to you if you want sways too. May or may not be necessary.
one thing you may consider is rsr type solid inner link on the steering rack. This removes the rubber and makes a real difference in steering feel.
Actually looks like elephants tie rod kit includes that. Def consider those
LPMM 03-09-2019 12:06 PM
I refreshed mine with OEM stuff because there were a few folks reporting fitment issues with the Elephant kit and/or no real added value based on seat of pants feeling.
Yes, along with Ricochet steering rack bushings.
I purchased the Rennline HD bushings and ball joints simply because I was ordering other parts as well. I had Andreas refurbished my control arms and based on the many he has done, he mentioned that the Elephant, Rennline, FVD, ... bushings seem to be all made by the same manufacturer. Besides, they all have the same hardness specs. I wouldn't sweat it too much, buy them from your favorite outfit and enjoy the improved ride.
Spokes 03-09-2019 02:33 PM
2nd that.
© 2019 MH Sub I, LLC dba Internet Brands
