C2 Suspension refresh - RS ride height
#31
I've ridden in a 964 that was low on V3's and the front end also bounced - really rapid little bounces. That would drive me insane. I know they are adjustable but the car's owner works for Porsche! I think that once they are out of the "sweet spot" they become unruly.
The H&R Deep Coilovers available in the States through Rotiform are designed for going low, I know several people running them... https://rotiform.myshopify.com/collections/suspension
#32
Ive looked at those deep coilovers. I ran H&R street coilovers on an Audi S5. From my experience, the H&R’s aren’t as good as KW, Bilstein, etc but for the street, they get the job done and this is a street car. It seems like you have a relationship with Brian at Rotiform, hook up a deal? Kidding
#33
Most H&R Coilovers use Bilstein internals, conversely I'm pretty sure H&R makes the Springs for Bilstein Coilovers.
I've also had H&R's on several Audis and VW's from standard to ultra low. The Deeps are not the same as H&R Street in any way.
#34
Do you happen to know the lowering ranges on the deep setup? Rotiforms site says up to 120mm but do know the full range off the top of your head? I believe the street set is 1-1.7” both front and rear.
#35
I don't but if I had to guess I would say 40mm is probably the minimum. My car is pretty low and there are some lower than mine. I could probably raise mine to above RS.
Found a crappy pic from when I installed them in 2013...
#36
Im curious to find the ranges so I’ll reach out to rotiform. These go way lower than I would want but it’s an option. It seems like V3’s and H&R’s are the only kits in the price range that go below 40mm in the front. Thanks for the info.
#37
I would rather run these high as opposed to running the others lower than they were designed to go.
I did new OEM mounts when I installed, that's it. It's a weekend car and I drive it down for Luft every year but that's about it.
I have a set of Elephant Racing tie rods getting ready to go in. While I may be too low to truly benefit, they can't hurt and I like the idea of the solid inner tie rods, especially for the money.
#38
Lorenzoh- depends on what you mean by "bounce"....
Bump steer is an issue at the lowest level w those struts, as it's lower than rs+10....but that's not "bounce" in my head....bounce to me would be more about rebound. Which would require revalving the bilsteins, which is easy enough to have done.
#42
Thanks!!
These are the ones I bought:
H&R 29813 Sport Spring https://www.amazon.com/dp/B00C7LVXEC..._GV6UCb3CDQF5N
I’m still debating what to do. I know this topic has been discussed countless times but I always like getting up to date information/ feedback.
#43
Anyway, it’s only bad over really rough surfaces...on smooth pavement they’re amazing.
#44
For the street, I think the PSS 9 or 10s are overkill. Sure they’re adjustable, but I’d rather have something that’s fixed and works well. Plus I’m not a fan of getting down on the ground and reached under the car playing with the settings. This is the third HR/Bilstein combo I’ve had and I love it. Just wish I could figure out why the front end is so bouncy....or as mentioned above the rebound seems out of whack. Not sure what the term is for it but I’m wondering now if my front shocks are not valved properly for the HR spring rate. If that’s the case, then did I get a bad batch?
Pete
#45
Originally Posted by Lorenzoh
thanks for the clarification. Are you suggesting that my front shocks are worn out/need rebuilding? They are the stock Bilstein HDs so I’m not sure why they’d need to be revalved?
If you switch to a "better" coilover set, you will likely end up with a higher spring rate, and will be over sprung when you have them set to the soft settings, which could be reason for the bounce. And the reports of the bounce in the kw v3 previously noted. As the spring rates will be more appropriate for the stiffer settings.
Anyway it's worth a call to bilstein to discuss. As it may get you what you want, and save you a few thousand in the process.
