Interior back to stock - carpet question
I'm putting my interior back to stock (ish) and taking out the RS carpet. I have a new OEM Silverknit kit from Bob / AppBiz and curious what anyone has used for back padding. IIRC when I pulled out the original carpet there was some heavier backing, especially around the floorboard area.
B
B
I used a combination of second skin - dampifier (self adhesive butyl insulation), 1/2in; 1/4in; 1/8in closed cell foam glued on top and Rennlist floorboards and kickboards. The whole Instalation looks very OEM.
Thanks!
Andrew
Thanks!
Andrew
B
B
Are you talking about the carpet or the floor mats?
I understood he is replacing the lightweight RS carpet with the thicker Silverknit AppBiz carpet and looking for a solution to fill in the floorboards.
If so, below are some photos from when I did the same.
In the last several photos you can see I have chosen to use the full rear seat bottom carpet option and keep the cushions removable (just closed them from the bottom so they look neat). That way if I chose to go full RS (once kids are to big to sit in the back) I just need to remove the rear seat backs. For the front floorboard many are using wooden planks cut to shape of the floor, but you can probably just fill in the gaps with heavy 1in foam then 1/4in on top of the larger area and then carpet mats from the Appbiz kit. This is what I did for the rear floorboards. It helps to keep them in place when the kids are monkey around there.
Thanks!
Andrew
Thanks!
Andrew
Nice work Andrew. I’ve done two recarpets and can see quality here. FWIW I used Dynaliner in one car for a complete relining. It’s made for the task with a self adhesive layer which adheres strongly.
Thanks!
Andrew
I went crazy with Dynamat and Dynaliner. In hindsight it was overkill but the beauty of using task oriented products is that you hopefully won't have mishaps like adhesive giving up with extreme temps.
Hey john, how do you find the interior noise with the dynamat and dynaliner? Does it work well?
Andrew - your tub looks pretty clean. Did you do anything to clean up the Gorilla Snot / Porsche adhesive? Not that it will be seen in most places, just curious, most especially underneath the seat area where all the electronics are. Again, IIRC the carpet was fully under the seats and then cut out for the various controllers
The Dynamat stops the drum effect that sheet metal has. It works based on mass. The dynaliner is a foam that helps to attenuate noise.
The Porsche OE system is similar except they use foam first then rubber. I'd say the modern products do make the cabin quieter but not say Cayenne quiet. It does make the car smell modern though
I did the full Monty on a car with water ingress. On my other car, the foam was fine and I just did the carpet.
https://rennlist.com/forums/964-foru...ginning-4.html
Good luck!
Andrew
Hi Dean,
