So who's the go-to guy for rebuilding distributors these days?
Merry Christmas and Happy new year!!!!
I'm in the process of dropping the engine/trans over the winter for a clutch job (100k and no record of ever being changed) and a few minor leaks and seeps (valve covers, rear main, timing chain covers, ps pump. etc). Nothing that leaks enough to puddle on the floor but knowing that they're there is driving me crazy. Anyway, I'd like to get the distributor rebuilt at the same time, again no record of being done. I'm a bit apprehensive of doing it myself and I'll have enough to do to keep myself busy. Who would be the go to guy to rebuild it? I searched on here and pelican and came up with a few names but every thread I found is over 5 years old. Also a google search found me a shop in Kansas City called RennsportKC which only has a few reviews but the ones they do have are good. Any recommendations? Dan |
I sent mine to SteveW, at Rennsport Systems, total rebuild was about $700, I would call him the go to guy for this, probably can get it done cheaper but not better
+1 - Steve W did mine too.
Originally Posted by dsan
(Post 15540930)
What is the source for bearings? I am being told they are NLA.
Thanks! |
Bearing Stock Shop in Germany was the original distributor that I found way way back a few years ago. And make sure you purchase the correct oiled bearings, as there was a guy spamming Rennlist selling a kit with the greased bearings that a few unfortunate and unknowing Rennlisters purchased. I believe you want 7201-BE-2RS.AH01 and NX12-XL X-life but double-check those part numbers...
Steve Weiner, Rennsport Systems did mine. Although I could have done it myself. It's a relatively straightforward diy.
Originally Posted by JasonAndreas
(Post 15761818)
