Diagnostic tools to rent/borrow?
Essentially I need to find a source to either borrow or rent a Bosch KTS301 (Hammer) or KTS500/PST-2, UDT999/PDT999... anything aside from a Durametric.
I'm having massive issues with the alarm system (throwing a laundry list of codes that cannot be cleared permanently), and the replacement module I acquired is doing the same exact thing. The car will start/run, however the alarm doesn't function properly. I want to see if it's possible to run adaptation or some other form of setting change on either module instead of throwing more money at it.
Thanks.
Thanks.
IHI KING!
Have you considered buying your own? ToreB sells one that does 90% of the Hammer functions. The only thing it doesn't do is bleed the Carrera 4 PDAS system.
https://www.bergvillfx.com/index.php...4-and-993.html
