964 accelerator sticking
Hey guys. Took the car out today and the gas seems to stick and not return as it should.
If I press the pedal down, it seems to stay on the gas even with my foot off it for a little while. I checked the obvious, like the floor mats being in the way. Under the hood, when the car is off... I moved the throttle with my finger and it seems to be slow to return there... so I am guessing it is not a cable either. Is this something someone of little car knowledge can work on themselves? Does something need to be lubricated? Or maybe a part is bad? Any input would be great. Thanks! |
Krakhor9, there isn't too much to the throttle cable system in these cars. Most if not all of the return/spring comes from in the engine bay at the throttle.
So either there is too much slack in the system or you've got some corrosion/gunk in the accelerator cable. I had a similar problem after I first got my '89 C4. Turned out the adjustment screw at the throttle body had back its way out and allowed too much slack. So when I released the pedel, it did not return all the way. Could be that. Good luck. |
If you have cruse control check that cable also.where the cable go's into the plastic at the throttle linkage mine would pop out and hold the throttle up.
