Fikse ZFs - 17” Rear Wheels... 9.0 or 9.5 inches?
I’m ordering up a set of Fikse ZFs and was hoping for some guidance as to whether I should get 9.0 or 9.5 inch rear wheels for my narrow body 1990 C4? Is one better than the other for tire sizes? I’d also like the proper offsets so I won’t need spacers. I’ll be running 8.0s in front. Thanks in advance! |
Originally Posted by August West
(Post 15451747)
I’m ordering up a set of Fikse ZFs and was hoping for some guidance as to whether I should get 9.0 or 9.5 inch rear wheels for my narrow body 1990 C4? Is one better than the other for tire sizes? I’d also like the proper offsets so I won’t need spacers. I’ll be running 8.0s in front. Thanks in advance! You can run 225/45 on 8 ET50 or 52 & 255/40 x17 on 9ET55 or on 9.5ET47, this latter was used on 964 Cup. W/ AWD the concern is matching f/r tire rolling radius |
Thanks for the reply, Bill. I suppose offsets are specific to particular wheels... the offsets for Cup 1s would be different from the offsets for Fuchs-style replica wheels. Is that correct? |
...and thanks for the reminder about F/R rolling radii on the C4... within 6% of each other IIRC. |
(Post 15452015)
Thanks for the reply, Bill. I suppose offsets are specific to particular wheels... the offsets for Cup 1s would be different from the offsets for Fuchs-style replica wheels. Is that correct? For instance an 8ET59 is slightly more aggressive than an 8ET52, another example a 7.5ET45 is comparable in fit wrt the lip to an 8ET52 |
(Post 15452018)
I used to run 8" front and 10" rear on my C4 but now run 8.5" in front and there is a noticeable difference with turn in with ess understeer so I'd opt for 9" rear for C4 if you have 8" fronts.
Neil |
Well I’ve ordered up 7.5 inch fronts and 9 inch rears. When Zuffenhaus had their webpage up, I remember them saying 7.5 inch for stock springs or 8.0 with 2.25” springs. I’ll be sure to post when they arrive and when mounted. |
Originally Posted by Bill Verburg
(Post 15452272)
I'd need to look it up but I think that ABS spec is w/i ~5%, the envelope for AWD is tighter
(Post 15451921)
Factory ran 205/50 & 255/40 on 7ET55 & 9ET55
Originally Posted by Atgani
(Post 15458003)
The 9.5” Cup rear wheels will require spacers to clear the oil pipes in my experience. When the switched to 19s the 9.5x18 had an ET47, No spacer used. when used w/ a 265/35 tire the 9.5 ET47 wheel has a backspace of 7.1"(180.4mm) though I have seen 10ET ET45 used w/ 275/35x18) wheel b/s is7.27"(184.7mm) this should be considered the max b/s that can be used on a 964, the 265 tire b/s is ~7.07"(181mm) a wider tire like a 275 would have a little more backspace |
https://cimg2.ibsrv.net/gimg/rennlis...778a6be67.jpeg https://cimg3.ibsrv.net/gimg/rennlis...ca1afb026.jpeg https://cimg4.ibsrv.net/gimg/rennlis...27041d5d1.jpeg
(Post 15458277)
The wheels used by the factory on 964 Cup were 9.5x17ET68, They used a 21mm spacer to provide an installed ET47, Yes, all Cups had a flattened oil line.
When the switched to 19s the 9.5x18 had an ET47, No spacer used. when used w/ a 265/35 tire the 9.5 ET47 wheel has a backspace of 7.1"(180.4mm) though I have seen 10ET ET45 used w/ 275/35x18) wheel b/s is7.27"(184.7mm) this should be considered the max b/s that can be used on a 964, the 265 tire b/s is ~7.07"(181mm) a wider tire like a 275 would have a little more backspace As I recall the C2 and RS run “unflattened” oil feed/return pipes. |
(Post 15465929)
https://cimg2.ibsrv.net/gimg/rennlis...778a6be67.jpeg https://cimg3.ibsrv.net/gimg/rennlis...ca1afb026.jpeg https://cimg4.ibsrv.net/gimg/rennlis...27041d5d1.jpeg Hi Bill, running the 9.5 x 17 ET68 Cup rears with a 21mm spacer leaves a lot of clearance between the tyre and fender. I think I ended using a 28 or even 32mm rear spacer to get the standard 255/40 rear tyres to fill the fender well out nicely. See attached images of my old car running this set up. As I recall the C2 and RS run “unflattened” oil feed/return pipes. Yes, the street cars ran unflattened oil lines, but they also used 9E55 w/ 255/40 x17.. This is strange because the 9 actually has a bigger back space than the 9.5 |
Here's a comparison of what was used on a 964 RS and 964 Cup
https://forums.pelicanparts.com/uplo...1543608709.gif |
Do you have to flatten the oil line with a 10” rear wheel, if you don’t lower the car too much....? Maybe a lower-than-stock-US-ride-height, but not-quite-RS-ride-height? |
