Fikse ZFs - 17” Rear Wheels... 9.0 or 9.5 inches?
On the ones I've seen they usually use a 993 10ET65 w/ 21mm spacer for ET44, thes have a couple more mm backspace than even a 9ET55, The tire of course usually protrudes even further(a 275 more so than a 255). So yes a flattened oil line is wanted.
Thank you for the reply. I would run a 255 or 265, nothing bigger, and a street tire, not an R-compound.
I don’t want to flatten the oil line if I can avoid it. Just because the car did not come this way.
Is there any negative to flattening it? How much does it really need...?
Sorry for the hijack OP
I'm running 9.5s but only see a 5 mm spacer...
All of this rim size and spacer information is interesting.
My car came with huge (plump) tires, so I better check how close the tires are to the oil line...
Fronts are 8s rolling on 235/45s (no spacer)
Rears are 9.5s rolling on 275/40s (with a 5 mm spacer)
I'm sure everything is fine, but given the rim size and spacer discussion, does any one know which reproduction rims these are?
...when used w/ a 265/35 tire the 9.5 ET47 wheel has a backspace of 7.1"(180.4mm) though I have seen 10ET ET45 used w/ 275/35x18) wheel b/s is7.27"(184.7mm) this should be considered the max b/s that can be used on a 964, the 265 tire b/s is ~7.07"(181mm) a wider tire like a 275 would have a little more backspace
Hi Bill, running the 9.5 x 17 ET68 Cup rears with a 21mm spacer leaves a lot of clearance between the tyre and fender. I think I ended using a 28 or even 32mm rear spacer to get the standard 255/40 rear tyres to fill the fender well out nicely. See attached images of my old car running this set up.
As I recall the C2 and RS run “unflattened” oil feed/return pipes.
