964 C2 Brake Master Cylinder Repair
I've been searching for a few weeks and can't seem to find a straight answer. Other threads seem to start by asking if anyone repairs these 964 C2 BMC ( 96435501503 ) and then they get side-tracked.
Summary, just had my car rebuilt and had a brake issue when I picked it up. I returned it and was told my BMC was leaking and needed to be replaced. I tracked a used one in Germany and picked up new bushings for it and handed it to the shop. I was then told that my old BMC was used with the new bushings and everything is A-OK (I spent almost $1,000 on the used BMC from Germany). I was annoyed but fine, as long as things are OK. Now I noticed that my brake fluid was disappearing quickly, and I tracked the leak to under the car between the master cylinder and booster (it was leaking on the plastic cover at the bottom).
I'm dropping the car back at the shop, but meanwhile I have the used German unit sitting here and I thought I might as well get it looked at properly and rebuilt just incase. Is there anyone out there that can do this?
Thanks!
Thanks!
