So, I'm a new '94 'big butt' owner myself. We should start a thread dedicated to the Turbo-Look 964 .... or is there one already?
Nice. I am not sure if there is a thread "dedicated" to the 964 Turbo-Look, but there are certainly many threads about them if you search on this forum. Mostly threads about current prices of the C4 Widebody though.
Since it is a 964 number and not 965?it should be correct , I have a narrow swing arm set ready to mount but will have to check the number to be certain ...Bert
This shows up as being a NB swing arm although the PET shows 964 331 021 (022) 00. I have a couple of spare arms I will check what is on my car and what I have. I would be curious what if any differences there are.
Something interesting... C4's rear hub and bearing are bigger than C2's. So, it looks like I need to order C2 rear hubs and bearings for the install.
Mr. Wolfe
I don't believe that is the case. The PET shows the C2/C4 and RSA all use the same rear hubs part number 964 331 065 06 Bearings are the same as well for all three.. They do differ from the turbo rear hubs which are part number 928 331 065 07. I have trailing arms from an RSA and a C4 both were identical as far as I could tell.
