964 Forum 1989-1994
964 C4 CV Joint question
Old 10-27-2018, 07:29 PM
minhnugen
minhnugen's Avatar
Default 964 C4 CV Joint question
Hey guys, just want to know if the CV Joints for the C4 are the same front and rear? They look the same but just wanted to confirm.
thanks
minh
Old 10-27-2018, 09:23 PM
Rocket Rob
IHI KING!
Rocket Rob's Avatar
No. The part numbers are different front and rear. Do you have PET? The front part numbers are on page 401-10 and the rear are on 501-05.
Old 10-28-2018, 01:00 AM
John McM
John McM's Avatar
Aside from some close to urban myths going around, only the inner CV joints are available. The fronts are so expensive you might as well buy a complete new driveshaft. I did that. The rear inner is the same as the Boxster and quite reasonably priced.
Old 10-28-2018, 04:46 AM
koenig_roland
koenig_roland's Avatar
availability of CV joints in germany was so bad, i decided to do an overhaul of my existing driveshafts (rear) and bought a spare pair for the front for the case, i ever need replacement there.
For a tracked car with low ride-heigh, i recommend to use a proper grease for the cv joints... Std. grease overcocked at the first trackday and the cv boot bursted.... With a proper grease from castrol (also avail for BWM with a BMW branding for the 5-series) is that problem gone
kos11-12 (11-23-2023)
Old 10-28-2018, 01:23 PM
minhnugen
minhnugen's Avatar
Thanks for the info guys. Yeah I think I’m going to just rebuild the CVs. Much cheaper for sure.
Old 10-28-2018, 01:56 PM
John McM
John McM's Avatar
Wise choice. It's far easier if you take the axle out of the car to do this and don't over grease the joints.
Old 10-30-2018, 12:40 AM
-nick
-nick's Avatar
Wish there were options like this available. And that they were priced slightly less than an appendage. Neat though-
http://www.kirkhammotorsports.com/book_aoe/aoe_11.pdf
Back to reality, has anybody had a complete axle, inner and outer, rebuilt? I have a spare pair of fronts that I’d like to send off.
Old 10-30-2018, 03:16 PM
JasonAndreas
Technical Guru
JasonAndreas's Avatar
I believe Robert Linton has those (metalore CV joints) on his 964.
Old 11-01-2018, 08:33 AM
Navaros911
Navaros911's Avatar
I think Vertex or ECS Tuning offered that service a year or two ago.
Quick Reply: 964 C4 CV Joint question
