Tiptronic fluid replacement question (filter/no filter?) - Rennlist - Porsche Discussion Forums
Go Back  Rennlist - Porsche Discussion Forums > Air/Oil Cooled Technical Discussion Areas > 964 Forum
Reload this Page >
964 Forum
Sponsored By:
Sponsored By:
Old 10-10-2018, 11:22 AM
Advman89
User
Default Tiptronic fluid replacement question (filter/no filter?)
My 91 964 is nearing the 60k mile mark and is need of a fluid change.
The job looks straightforward enough from the various posts I've found. Couple new seals, lots of fluid...<<insert joke here>>
My question:
Should I replace the trans filter (requires dropping the pan, new seals, etc). And if so, should I use OEM or PORSCHE filters?
The car has been treated nicely it's entire life, so not sure if it's needed, but thought while I am making a mess...go all the way
Thanks in advance.
Advman89 is online now
Old 10-10-2018, 12:06 PM
Deserion
Deserion's Avatar
I would definitely change the filter. Generally if you go with Mann, Mahle, or Hengst you’ll be fine. Just do a drain and refill.
Deserion is offline
Old 10-10-2018, 01:12 PM
Advman89
User
Pelican lists it as OEM ($77) v PORSCHE ($235)
Just making sure I'm not missing anything.
Thank you for the response.
Old 10-10-2018, 04:27 PM
JohnK964
JohnK964's Avatar
get a similar pump to push the new fluid in
JohnK964 is online now
Old 10-10-2018, 07:03 PM
RicardoD
RicardoD's Avatar
I used one of those garden sprayers to pump and flush fluid per the workshop manual
Ricardo
RicardoD is offline
Old 10-11-2018, 12:54 AM
RicardoD
RicardoD's Avatar
Found my DIY instructions on how to do this here:
https://rennlist.com/forums/964-foru...and-lines.html
RicardoD is offline
Contact Us About Us Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
