Oil Level Gauge Guestimate
Hey all,
What would you guess the number of litres of oil to be between about the 3/4 (2 o’clock position) and the 1/4 (4 o’clock position) on the oil level gauge?
Anyone know?
Thank you!
Anyone know?
Thank you!
A little bit of oil does move the needle a good amount, so like Goughary said, go slow. Don't forget to check the dipstick to make sure the oil level is good too.
Technical Guru
After years on Rennlist i finally googled what a 'quart' is in the metric system !
Thanks all!
When you are all talking about 'bottles of oil', you mean litre bottles, right?
@JasonAndreas - so you mean, add oil with engine still running and keep an eye on the gauge as well, and if this moves up even slightly, stop?
