clutch disc compatibility
i don't think so.
The flywheel from the kit works on 964, but i don t know about the disc. Found a nice price on this combo on ebay, the seller claims to work on 964, but i don t know nothing about the compatibility of the disc.
Any help would be greatly appreciated.
Regards,
Doru
Regards,
Doru
Technical Guru
Is this a light flywheel sprung disk? If so. The clutch may work with the right pressure plate and throw out bearing when used with the light single mass flywheel. My car has the 997gt3rs 40 setup. The flywheel in my gt3rs is same 964 part number.
Many people have moved from a double mass to single mass flywheel as a performance upgrade. However, it introduces issues with engine stalling at low RPM. This can be solved with a new ECU chip, such as the ones Steve Wong sells. I myself am still on a double mass flywheel.
