Design 911 Fuch Replicas
The figures look probable to me. The original Fuchs are extremely light and their weight is correct. A OEM Cup1 17x9 ET 55 weighs in at 26lb/11,9 kg's.
A good wheel will weigh in under 20lbs. Genuine 15/16” fuchs are incredibly light. It’s too bad that Porsche started using heavier wheels for the late offset cars.
Here is a shot of my replica cup 1 wheels with 6mm front and 15mm rear spacers. Making them effectively 7.5” et46 and 9” et32. Camber is -1.4 front and -2 rear and sitting at rs height. The camber will allow for less offset than is usual. The offsets are surprising, but there is even some space left under the arches. No rubbing, or rolled fenders in the rear. The front only rubs on the inside rear of the well if I’m sliding and giving lots of opposite lock steering correction. In that instance, the suspension is compressed on the wheel that is turned outward. I try to minimize those instances
(the Fuchs are actually substantially lighter than even the OE magnesium Cup1´s on the RS -92)
Real Fuchs are Forged, not Cast. Hence the weight difference.
