Reverse light switch access
Hi,
I think my reverse light switch is broken. No lights going on. Bulbs are good and Rear Fogs, AC are working (which are on the same line, especially the AC Clutch relay). Is it possible to get to the reverse light switch without a lift? Where is it located exactly? Only finding 993 DIY.. Cheers |
Tiptronic or Manual?
Manual C2
It's on the passenger side of the transmission
Easy to get to on jack stands. Carefully pull the boot. Pull the pins out of the unit and re-solder them to the wires. Plug them in and you should be set...assuming it's the normal problem. |
Thanks, I'll chek it out!
