964 Forum 1989-1994
Welding targa top in permanently
Old 09-05-2018, 11:48 PM
Goughary
Goughary's Avatar
This is the booklet i referenced. I don't have a pdf. And it's a little long to scan. But this is what you are looking for:
There are two earlier copies on eBay. These aren't 964 specific but the information is pertinent.
Old 09-06-2018, 12:35 AM
FrenchToast
FrenchToast's Avatar
To weld it you would probably need to do it with the car loaded on the ground with the doors closed, or with a fully stripped and unladen shell (even stripped the shell could be sagging). Otherwise, welding it on an unladen car you would end up post-compressing the roof once the car is on the ground. Then the doors would probably never close properly, glass seals might not work, and the panel could buckle.
But as it is now, I imagine something can be done with the seals to fix most of the leaks and noise.
Old 09-06-2018, 12:37 AM
Bloose993TT
Bloose993TT's Avatar
Swap it for a 993 Targa roof.
Old 09-06-2018, 01:42 AM
cjoenck
cjoenck's Avatar
Attachment 1290167
Thank you very much. This is great as I didn't know this actually existed. I found a 1991 edition on eBay and bought it.
Old 09-06-2018, 07:58 AM
ffc
ffc's Avatar
Originally Posted by cjoenck
It starts dripping water every time it rains from the corners where the targa top, windshield, door come together. It is not a stream but enough to get my arm and pants wet. I usually stuff a towel in the corner held up by the sun visor. Not an elegant solution to be sure. Problem is that air is pressing water all over the place and it's not immediately obvious where the leak is so it's hard to reproduce the leaks with a garden hose.
I am intrigued by the d Moris hardtop idea though. Need to look into pricing and shipping options. Thanks for the suggestions.
This is worth a look.
(It helps if you speak German or know someone who can translate but the video helps a lot).
Also this http://forums.pelicanparts.com/porsc...ter-leaks.html
Apologies if you have seen these before.
Old 09-06-2018, 08:14 AM
Deserion
Deserion's Avatar
Awesome, thanks for the info.
Old 09-06-2018, 12:10 PM
cjoenck
cjoenck's Avatar
The video is very helpful - I do speak German and happy to translate if someone needs it. I think I need to rename this discussion to something like " How to seal a targa top ". More to come
Old 09-06-2018, 01:02 PM
LPMM
LPMM's Avatar
Thanks Rob... Will be keeping an eye out to ****** a copy.
Old 09-06-2018, 01:36 PM
Deserion
Deserion's Avatar
That would be fantastic!
There is a copy left on eBay, at $135 however.
Old 09-06-2018, 01:44 PM
LPMM
LPMM's Avatar
Thanks, I must have missed it the first time around. I don't know how much the other one was but I made what seems to be a more reasonable offer (at least to me), so we'll see.
EDIT: Went back and forth a couple times and made a deal with the seller. Thanks again for the heads up.
Old 09-06-2018, 11:00 PM
Marine Blue
Marine Blue's Avatar
That video is excellent, the visuals are enough to understand the adjustments on the tops.
Old 09-06-2018, 11:30 PM
cjoenck
cjoenck's Avatar
Does anybody know what kind of putty they are using for the seals? They only talk about permanently elastic (ie non hardening) putty that I assume will withstand head an cold - although weather in Germany is much more moderate than in parts of the USA. Glue is obviously weatherstripping glue and crazy glue.
Old 09-06-2018, 11:56 PM
Deserion
Deserion's Avatar
I’ve concluded that it’s butyl putty. Some spots on mine have hardened but still had some malleability left, and what they’re using is the same consistency of the huge butyl roll I have on hand. If I’m wrong, someone please correct me.
Old 09-07-2018, 12:56 AM
Marine Blue
All I know is that the black putty is a major PITA to clean, the previous owner used it copiously to try to seal the front. With every top removal I managed to get the putty all over my hands which was fun.
Old 09-07-2018, 12:50 PM
A914MAN
A914MAN's Avatar
I've used foam rod to shim out the seal on the windshield frame, up at the top corners. Years ago, I thought this was only a problem with the 914
Quick Reply: Welding targa top in permanently
