964 Forum 1989-1994
Rear Reflector Rehab
Old 12-08-2018, 04:53 PM
  #91
964Andrew
964Andrew's Avatar
I think it looks very good on the silver car. How did the edge mounting go?
Thanks!
Andrew
Old 12-08-2018, 05:27 PM
  #92
Silvertarga
Silvertarga's Avatar
This was installed on a Euro rear reflector which is a bit different than ROW. In addition to the Metal Louvers (my ROW was plastic louvered) the lens had a bunch of black tar at the bottom (which looked as if it came from the factory that way) and that made it tricky to remove, its why I used a dremel, on parts that didnt have enough protrusion to use the edge rubber I ran a bead of glue.
Seriously I dont think the edge trim is needed, your drilling template was spot on
I still havent tried out the Silver metal screen, will post pictures when that is done
Again I want to thank you for making this available, I have had nothing but compliments and positive comments!!
Old 12-27-2018, 03:15 PM
  #93
Badluck
Badluck's Avatar
This is as far as I got today.
Notice the debris that has spread all over my working area. Years from now I'll probaby still find bits of it in some of the corners.
Wear some safety glasses if you're tackling this.
Old 12-27-2018, 10:33 PM
  #94
964Andrew
964Andrew's Avatar
Bravo, this is looking great !!! If you find that the mushroomed edge where the reflector was attached to the lens is to thick to slide on the gasket, you can trim the overhang. It will help the seal seat nicely on the reflector.
Thanks!
Andrew
Old 02-13-2019, 12:11 AM
  #95
964Andrew
964Andrew's Avatar
Hi, I think the last of the first batch DIY kits are now delivered. If you haven't received yours or the kit was damaged please let me know. Otherwise I have 4 "safety" DIY kits available.
$115 USD + shipping
Thanks!
Andrew
Old 03-09-2019, 05:24 AM
  #96
Badluck
Badluck's Avatar
Finally found the time to finish my kit. It was quite a bit more time involving than I thought, basically because the reflector I sacrificed was in such a bad shape to begin with.
Here's some pics of the final product:
P.S.: ​​​​​​I want an award for posting pics of the dirtiest car ever.
Old 03-09-2019, 05:27 AM
  #97
Badluck
Badluck's Avatar
@Andrew: As you suggested I did trim that mushroomed edge. Had to make a couple adjustments (meaning cutting away some bits) to the "flaps" on the sides as the grill didn't sit as flush as I liked it on the sides.
Old 03-09-2019, 08:20 AM
  #98
dukmon
dukmon's Avatar
I thought I’d have mine completed and installed by now. Trying to accomplish this at my office has been the main reason for the delay.
Soon, I hope.
Old 03-12-2019, 10:37 AM
  #99
964Andrew
964Andrew's Avatar
Looks flush. Good work. Did you capture any shots of the process and how you made the adjustment?
I hope everyone is enjoying the kit. Keep the photos coming.
Thanks!
Andrew
Old 03-18-2019, 03:05 PM
  #100
964Andrew
964Andrew's Avatar
Winter if over, time to dust off the old girl. Rear panel in the sun looked very good. Still have 4 kits left. Let me know if you are interested int his conversion.
Thanks!
Andrew
Old 03-18-2019, 03:10 PM
  #101
dukmon
dukmon's Avatar
Looks great. Car too!
I bought an additional center reflector recently to use while I take forever to mod my original one.
Old 03-21-2019, 12:39 AM
  #102
JNATITUDE
JNATITUDE's Avatar
Andrew,
I will take one
Old 03-21-2019, 01:06 AM
  #103
964Andrew
964Andrew's Avatar
Originally Posted by JNATITUDE
Andrew,
I will take one
Hi, thanks for the interest. Please email me your address at amilosz@gmail.com and I will calculate the shipping for you.
Thanks!
Andrew
Old 03-23-2019, 06:29 AM
  #104
bw-porsche
bw-porsche's Avatar
Hi Andrew. If there is one left I will take it please. I am UK based though. I think you have sent at least one kit over here? Thanks.
Old 03-23-2019, 12:23 PM
  #105
964Andrew
964Andrew's Avatar
PM sent.
Thanks!
Andrew
Quick Reply: Rear Reflector Rehab
