Fog switch removal?
Fog switch removal?
Hi,
Kinda dumb question, but I don't want to just randomly start prodding. How are the fog switches affixed to the dash face? I'm looking to remove my useless fog switches.
The **** that you pull just comes off by turning... like a bolt.
Then you will see how the switch is held to the dash.
The black plastic ring of the switch you see now can also be unscrewed. How I did this was with a pair of pliers to squeeze c-clips for installation. Insert the two pins from the pliers in the little holes you see on that plastic part. Turn counter clock wise (if I remember correctly) and done.
Thanks for posting this part #. I swear in my pile of parts I bought one, can't find it.
So, option 1 is replace with a plug (no fogs anymore)
Option 2 is replace with another 12v plug. I bought a factory 12v outlet but I don't think it will fit right in the fog plug? Size seems different?
So, do any of you have an option for one that will fit w/o drilling the dash? An outlet with a flip cover w/ USB would be awesome...
This is what I used.
I actually took the cover off. You will need to carve the fog light hole a bit wider to fit it. It's easy foam material on the dash. Downside is reversibility if you wanted to go back to a fog light button. But that USB port comes in handy as well as the voltmeter. I will try to post a pic today when I get home.
