Engine rebuild terms and costs?
#46
Until you open it up and know exactly what is needed it is just a guess and I have seen it go either way. Although when people usually ask I just say months. No matter what there is always something that drags out. I waited months for a part from Porsche that I could have machined in 30 minutes if I had the dimensions.
#47
Every builder is different and will approach a rebuild differently depending on what you are spec-ing the motor. More experience doesn't necessarily mean less time, nor should it. Experience often leads to what works for a given situation, what problems to look for and solutions that address a given scenario. Rather than looking at how many hours, I would be asking for a given outcome, what should I be the considerations on my specific motor given its, mileage, previous work, etc.
My motor went well above the time and cost initially planned and discussed, but most of the overrun came from decisions I made to future proof the motor.
However, the longer a project goes, you will always find additional items to do...my "build a bulletproof, better than OEM quality motor" became a "bulletproof, better than OEM 3.8, RS Varioram equipped but still motronic run" motor;p
#48
I am in the process of rebuilding my motor i was wondering would you guys use all oem parts or aftermarket?
example :valve springs valve bearings chain sprocket etc??
i see a lot of aftermarket company selling the same parts for 1/3 of oem porsche parts.
my question is would it hold up in quality wise vs oem parts??
anyone here rebuild their engine with aftermarket parts?
rendernyc (08-03-2023)
#49
^^^ Try contacting EBS Engine Builder Supply and see what they recommend. Many of the factory parts are just repackaged with P tax added. Most upgrades for these engines are made by other sources. All depends on how far you want to go, if you want a stock build or plan to take it further and how far. If you have never rebuilt one of these there are some interesting threads on Pelican including one on sealants. So many opinions on whether to use the factory recommended Loctite 453, threebond or several others, if you should bond the webs and other parts or not etc. Do your research there are a lot of things you can do differently than factory but that is up to you.
#50
#51
Let me answer to give you one piece of data: I got billed between 55 and 60 hrs. Experienced mechanic, rebuilt to stock specs.
His billed hours are generally quite reasonable, meaning time he spent looking for parts is not likely to be included, nor were the hours we discussed things.
I just paid up with no argument since al decisions to increase cost were mine in the end... based on best effort estimates.
#54
^^^^That seems a bit high especially if they are billing $100 or more an hour. What did the work encompass?
#55
Some other small maintenance things, but nothing major... though the front heater blower motor replacement may be few extra hours.
The hourly rate was not 100 USD... a good bit less... fortunately.
#57
From a labor point of view: Removal of engine, complete strip down to bottom case split, some parts cleaning (done in house), putting all back together, reinstall, testing... that was it. Ah, some tuning was done as well since it was struggling running hot before.
In the US. The names that come to mind are Rothsport Racing, Rennsport Systems and Gaswerks Garage. I know Gaspare at Gaswerks and he is a true artist IMO and is more of an old school engine tuner you want to build your early outlaw engine. I have seen work come out of some other very high end well known shops both east and west coast and have to say I saw some things that concerned me so I will keep the list short . Although they may have been isolated incidents.
#58
That is a true challenge here, but things are improving. It surely adds to the increase in hours... but the quality control on the mech's end needs to be paid for and is part of the end product he sells.
