Injector question
Injector question
My 964 is running strong. No issues at all, but...
Yesterday I used Scantool to run the injector valve test. 5 of 6 injectors produce the expected click when tested. Injector 6 is not 'clicking'.
The car is not running on 5 Cylinders, no petrol smell, idle rock solid, power up the red zone.
Should I be worried about injector 6 not clicking?
No error code related to valve not working.
Injector Coil resistance is 16ohm (which is good)
Power output connector is 12v
Did not test pulsing yet. Don't know if I need a scope or use a multimeter to check this, any tips welcome.
Technical Guru
