964 PPI results
964 PPI results
Hi RL,
I’m trying to make my leap into 964 ownership. I’ve been looking off/ on for years and I’m trying to buy a 90 C2 manual coupe with 110k miles. I just got the PPI results and here were the areas of concern:
Signs of Harness and roll cage
Limited/ no service records. No records of brake flush after track evidence
Large amount of oil leakage
Mismatched tire brands in front/ back. Dates are out of code
Shocks leaking, springs worn
Belts are worn/ frayed
Cars stumbles when warming up - O2 sensor?
Vehicle shows sitting outdoors for periods
No A/C - smoking from oil leaks and doesn’t blow cold
Scuffs uunder front end
Hood release broken
Oil gauge isn’t registering
Oil drips can be seen on ground when idilng
Large amplifier and wiring in front trunk
Hood appears to be refinished
Numerous dings
Rust on left fender
Cracked paint on hood, dent through paint
Cracked turn signal
Rear spoiler doesn’t function
Brake sensors are tied
Brake warning is on dash
Brake fluid looks dirty
Wetness around brake caliper bleeders
R12 AC caps
Oil pressure warming is major concern if not a sensor. Engine will most likely need a reseal, possible new bearings due to oil pressure issue. Needs new tires, shocks, springs, complete alignment and corner balance.
So now I’m trying to make a decision on this local car with a price a little over $50k. It’s a limited slip car and I’ve wanted a P car since I was a kid. I’m dead set on a 964 C2 coupe in a certain color combo so I’m conflicted. I know these cars cost money which I’m prepared for but I’d love to hear from the 964 owners on these concerns. Thanks guys!
Hood release broken
Numerous dings
Rust on left fender
Cracked turn signal
R12 AC caps
Depends on what are you looking for in a 964? Long term ownership, track use?
I know the feeling of finding something that you've been dreaming about and is now in your sights. I'm in a similar boat as you...I'm looking for a forever car and this sounds like something I'd pass on. Seems like a lot of sorting needs to be done.
Would you rather dump a boat load of money into this car or wait for one that is sorted, as you say you've been looking on and off for years. Rust scares me off.
What's the color combo?
It's not a rare combo, Black/Black, but that’s what I love. I don’t mind putting money into a car but I’m so busy with work that ideally I was looking for something more well sorted.
Will you be doing the work yourself or will you be paying to have someone rebuild it? Without knowing the cause of leaks and other issues I’ll give a best case scenario on cost:
- Suspension rebuild with shocks, springs, steering rack, bushings etc: $6500
- Engine rebuild: $13k (minimum)
- Basic Respray to address paint issues and rust: $10k minimum
- Rebuld brakes: $3,500
- AC rebuild: $2500
So your $50k car just became a $86k car with possible prior accident history, no prior records and higher miles. None of this includes any interior work which I would be surprised if it doesn’t need. I wouldn’t walk away, I would run away from this. Maybe I’m out of touch with 964 prices but this car seems excessively high considering the issues.
Personally if you’re willing to pay that much I would wait for the right car to come along and spend the money for a well maintained car instead. Open your search up to the entire country and if money isn’t an issue have a trustworthy dealer do the search for you and pay their premium. Another alternative is to buy a black/tan or black/grey coupe and have the interior redone in black. Keep the original parts if you do decide to sell. Then sell the black interior parts separately.
- AC rebuild: $2500
- AC rebuild: $2500
So your $50k car just became a $86k car with possible prior accident history. None of this includes any interior work which I would be surprised if it doesn’t need.
- AC rebuild: $2500
My suspension numbers might be a bit high but I’m also assuming tie rods (inner/outer) are shot and their will be some upgrades made along the way since you only want to do it once. Having just had it done the pricing is actually pretty close.
If you're willing to consider a C4, I know someone in Westchester with a black on black 1991 that is thinking about selling a car with some issues but in better condition than that for a lot less.
Sounds like too much money to me.
Thanks to everyone who took the time to reply and provide insights, it's very helpful and appreciated.
The seller said the leaks were a small fix, $1,500 to fix but didn't mentioned most of the stuff that came up in the PPI. It looks like it's a whole can of worms looking at the report.
I'm planning to work on my car but I also don't have a ton of free time so I'd use my independent mechanic for a lot. Thanks for providing advice and a breakdown on some costs, it's very helpful.
That's kind of where my head is at. I know these cars require work regardless but I'd rather pay more for a better one with less issues.
I'm hoping to find a C2 but I'd like to hear more about this car. Would you mind messaging me with some info? I really appreciate it.
Yeah, i'd rather pay up for the right car. I just don't want to pay up for one that needs a ton of work. Beautiful car in your picture btw.
Run Forest Run
Not worth $50k. Car sounds like it needs a min of $10k to get sorted, but probably allot more if you want to make it nice.
