Pfixit DVDs! where to get them!
hello guys,
I have been looking for the Pfixit DVDs for months with no luck! Any chance anyone on this board has a used set and no longer need them? please help
Thank you
Thank you
I'm surprised these are no longer available.
I have a PFixit DVD set and used it amongst other sources for my rebuild. I may use it again for my current rebuild, but it's not well formatted in my opinion as you have to search through the DVDs for particular steps.
I put a lot of rebuild posts in my C4 light refurb thread https://rennlist.com/forums/964-foru...refurb-42.html and may do a specific thread for this rebuild as I refer to my own work rather than repeat the research BUT I'm the first to admit I'm an amateur so wear your big boy pants if using my info. I did end up with an engine that started and is leak free so I can't have got it too wrong!
What is your timeframe and where are you located?
I am new to flat six too and can use any resource possible, but man! those samples on youtube make me want them.
Located in Kuwait, still couple of months before project starts.
The DVDs are good as a starter, especially if you learn visually. Check out my thread if you have the time. You'll need to buy a few specialist tools and that will take time. Good Luck.
Thank you
I have the complete set of pfixit engine rebuild DVD's I can part with.
1 - Crank Shaft Assembly
2 - Sealing The Crank Case
3 - Pistons & Cylinders
4 - Oil Return Tubes & Cam Housing
5 - Timing Chain Housing
6 - Rocker Arms
7 - Camshaft & Sprocket Assembly
8 - Outer Engine Assembly
9 - Final Section
Similarly to John McM I used them together with many other resources.
PM me if you are interested.
Thansk!
Andrew
6 - Rocker Arms
9 - Final Section
Thansk!
Andrew
6 - Rocker Arms
9 - Final Section
Thansk!
Andrew
6 - Rocker Arms
9 - Final Section
Thansk!
Andrew
6 - Rocker Arms
9 - Final Section
Thansk!
Andrew
6 - Rocker Arms
9 - Final Section
Thansk!
Andrew
1. Make the chapters shorter so there is less to wade through when doing a rebuild in a piecemeal basis.
2. Give an online viewing option for DVD buyers
3. Put every torque setting in the descriptions; and
4. Don't skip over tasks e.g. he was having problems with the piston circlip, then the video jumps to it completed. That's cheating and it's a vital step!
Pfixit DVD’s?
6 - Rocker Arms
9 - Final Section
Thansk!
Andrew
6 - Rocker Arms
9 - Final Section
Thansk!
Andrew
thanks
nic
