Help - unidentified crumbling connectors
Good news and bad news
Well the connectors arrived long ago but I got sidetracked and only got back to the 964 project a few days ago. So here is the scoop. I have good news and bad news. The good news is that the connectors fit into the corresponding connectors perfectly. The bad news is that they don't quite fit the engine bracket that secures the connectors mechanically. So if I use these I will have perfect connections from an electrical perspective but I will have to find some other way to secure them to keep them from floating around in the engine bay.
I am currently investigating some light machining on the connector and will post here if successful. If not it can always be jury-rigged with mechanic's wire or zip ties although I really find that kind of repair distasteful. However, I might have to go that route and wait for an engine drop to replace all sensors and switch over to the new style plugs. I have provided a link to the connectors that are made by TE and sold through Mouser.com. I paid about $6 CDN each and yes they will sell them one at a time. The part number is 1-962581-2. Here is the link and a photo follows http://www.te.com/usa-en/product-1-962581-2.html
Connectors are cheap- i would just cut them to fit. Shouldn't be too tough. They don't look much bigger than the oem connectors...a little cutting and sanding and they will look like they were made for the car...
The other thing I forgot to mention is that the connector does not include the metal tabs that attach to the sensor wires. They are available in many configurations and different platings like gold, silver or tin.
I ordered several different kinds. Here is one example of what I ordered. http://www.te.com/usa-en/product-1-962916-3.html
You can also get little rubber plugs for the wires to help make a water-tight connection. However a rubber boot that covers the entire connector is not available. I plan to use heat shrink tubing for that.
https://rennlist.com/forums/964-foru...rts-hacks.html
I actually tried that. I ordered the exact part number you listed and when it arrived it came with the new style plug. The other issue is that my old sensor is fine, so I don't really need the sensor or the hassle of installing it and figured it would be easier to cut and splice in a new plug. I am no longer sure it will be easier, but I am determined to make it work. FYI, the sensor with the new plug was ordered from Amazon. There may still be vendors out there who have the old style plug but I have not found them.
Success. Connector fits bracket now.
Well it really does stink. When a vendor decides to send you something you did not order they should call first. However, the vendor admitted his mistake and I got a refund so its all good.
Also, I finished the mod I needed to make the connector fit. The groove in the connector needed to be a little bit wider and a bit deeper. I was able to do this with a drill press, a cross-sliding vice and a 3/32" diameter end mill. One pass on each side and the job was done. Very easy. See pix below. I am pleased!.
Connector fitted to support bracket
Widening the slot in the connector
Cross-sliding vice setup
I never got to talk to the vendor since the return was handled via Amazon but the vendor was B2C Auto Parts and I exchanged several emails with them. I gave them the part number of what I ordered and the part number of what they sent. They never offered to send me the correct one, so I assumed they no longer have it. I would strongly advise anyone ordering this part to first contact the vendor to make sure they have and will ship the old style plug sensor.
UPDATE - Vendor does not have old style plugs
I just emailed the Vendor B2C Auto Parts and they said they no longer have the old style sensors. If my sensors ever fail I think I will make a short adapter cable so I don't have to mess with cutting and splicing into the main harness.
Connectors installed and car started
I finished wiring in the new old-style crank sensor connector. This was the final job that was keeping me from trying to start this 1992 964 C4 that I bought and rec'd in March. It had been in dry storage for 15+ years.
Today was the big day and I am really pleased to announce that it started on the second try. But man did it pump out a lot of smoke. Since it was in my basement, I could not run it for long. Now I will have to get her down off the jack stands and outdoors for some more testing. Lots of work still lies ahead, but its great to reach this stage. I want to thank all those who helped me on this journey through my various threads on rennlist. Cheers to you!
Last edited by No_snivelling; 06-26-2018 at 09:07 PM. Reason: embedded video did not work
