92 USA CUP BRAKES
92 USA CUP BRAKES
Can someone provide/ confirm the OEM part numbers for the front and rear rotors, pads and calipers?
Front Rotor(s) 965-351-041-01 Turbo
965-351-042-01 Turbo
Calipers 965-352-421-02
965-352-422-02
Pads 965-352-939-04
Rear Rotor(s) _____________ ? Drilled
Rear Calipers ______________?
Any help is greatly appreciated
965-352-422-02
Pads 965-352-939-04
965-352-422-02
Pads 965-352-939-04
965-352-422-02
Pads 965-352-939-04
front
rotors
965.351.043.00 964T2/RS front Brake Disc (32x322mm) L
965.351.044.00 964T2/RS front Brake Disc (32x322mm) R
but I believe that the later 3.6t rotors will also work, 993RS or turbo will not
965.351.045.00 964T3.6 front Brake Disc (32x322mm) L
965.351.046.00 964T 3.6 front Brake Disc (32x322mm) R
calipers
965.351.423.01 caliper 965, 964RS L
965.351.424.01 caliper 965, 964RS R
rear
rotors
951.352.041.91 964RS rear discs (24x299mm) x2
calipers
993.352.421.00 - Carrera RS L
993.352.422.00 - Carrera RS R
Thank of the reply Bill
Do you know the correct 964 part number before the 993 part number replaced the rear calipers? Or can you recommend someone who restores calipers? I'm trying to keep it original.
Sincelrey,
brian
Sincelrey,
brian
