Are front spacers (5mm) REQUIRED when going to 17's
I'm no expert on anything but I dont see why you would need spacers if they fit and don't fowl on anything.
I had to put 3mm spacers on mine as the brake calipers were almost touching the spokes, but that's with my particular wheels.
Are you running Cup 1's?
Width, ET and tire sizes?
Turn the wheels lock to lock and see if they touch anything. If they don't, your all set. You should also do this while driving. Also, might want to check how close your passenger side rear tire comes to the oil line.
I used 5mm spacers in the rear for a little more clearance.
I have an '89 with Cup 1's (replicas) and the spacers (steering block spacers) the literature is referring to are the ones on tie rod ends to limit the movement and to avoid tire contact at full lock with inner wheel well.
I never installed mine and just take my time turning around so you don't rub.
Part numbers are Steering stop: Part Number 964 347 325 02 (two required)
No other spacers needed.
Cheers!!
Cheers!!
I have MY 10 spokes on my mine, 17X7 up front with ET50 running 205/50/17 at RS hight with no rubbing at all. But I do not know if the PO made any mods to steering stops.
How many folks are running the revised stops?
Porsche Cup 1's 7/9
225/45's
255/40's
52 and 55 offset
I haven't notice any rubbing...
HOWEVER..I would like to bring the rear tires out a bit for aesthetics. Spacer recommendations? I know I'll need longer lugnuts.
Thanks all...
225/45's
255/40's
52 and 55 offset
Thanks all...
