Brad Penn: not for use with catalytic converters?
Hi guys,
I was about to order some Brad Penn 20w50 to top off my 1993 964 (which I believe is running Rotella 15w40 from PO but I am planning on switching at some point). It says on Pelican that it cannot be used with catalytic converters but it seems that many folks here are using it, is that relevant? https://cimg7.ibsrv.net/gimg/rennlis...8f613457bb.png Thanks! |
Originally Posted by _Remi
(Post 14802609)
Hi guys,
I was about to order some Brad Penn 20w50 to top off my 1993 964 (which I believe is running Rotella 15w40 from PO but I am planning on switching at some point). It says on Pelican that it cannot be used with catalytic converters but it seems that many folks here are using it, is that relevant? https://cimg7.ibsrv.net/gimg/rennlis...8f613457bb.png Thanks! mobil 1 15w50 or the motorcycle one |
Originally Posted by The Italian Pursuit
(Post 14802702)
it will shorten the life of the catalytic converters. mobil 1 15w50 or the motorcycle one |
Never heard of that. I guess I would rather replace a cat than rebuild a engine. They changed the name to Penn Grade btw.
Almost all oils worth using in our non-hydraulic lifter engines contain a higher level of ZDDP for protection. I have 85K on my car with no signs of degradation to the cat. Don't think it's anything to concern yourself with.
But if your cat does give up the ghost, replace it with a 200 cell cat for a little more power and sound. |
Or you can consider this blog where writer claims amount of ZDDP is not reliable measure of protection. He seems to have not only experimental but real world data to support his claims.
For an air cooled engine you need sufficient viscosity. The writer goes into some detail about this in his posts. I am considering Castrol GTX as a good alternative as it outperforms Mobil1 15w50 with lower ZDDP level. The writer has way more creds in area than I have so its difficult for me to argue with his results. Dan |
Just do a cat delete and then you don't have to worry about the cat going bad :)
High zddp oils degrade the cat, which is why low zddp oils were developed. That doesn’t mean that more zddp is better. Please don’t remove your cat. A sport cat flows just as well while still cleaning up the exhaust. The number of times my eyes have watered from sitting behind a non-cat car in the autocross grid, or in traffic behind a “tuned” Honda. Don’t be the Honda... |
I thought I saw a post by Steve Weiner stating he buys Brad Penn by the ton? Seems like he would know. |
Ok thanks guys, I went ahead and have already received the goods. It is indeed rebranded (and will be a good excuse to upgrade to a sports cat if need be).
https://cimg1.ibsrv.net/gimg/rennlis...bd355d1ebd.jpg |
FWIW,.....
After 44+ years, I have NEVER replaced a cat because it was poisoned by ZDDP. Cats fail due to excessive heat caused by lean or rich fuel mixtures. I suppose if an engine was burning excessive oil (due to guide wear, blowby, or high oil levels in the tank), it could happen, however I chalk those things up to human factors. |
The issue the conflict between the US EPA's requirement of 100,000mi cat life and simple chenistry
In use the P in ZDDP is transported to the catalytic surfaces and over time interferes w/ the cleansing action. They just gradually become less efficient. The protective part of ZDDP is the Zn which also is used up over time, change your oil regularly is the solution to that. Generally an owner is more concerned about engine MTBR rather than cat efficiency over time, the obvious exceptions are those that live where there are annual sniffer tests, which will detect the reduced catalytic efficiency eventually. From early experience when ZDDP reductions first became widely noticed a min of ~1000/1000 seems to be necessary, M1 FS 0w-40 @1100/1000 which was recommended by Porsche for many years is right at this minimum. That said too much ZDDP is as bad as too little, There is no need for 1700/1700 and up except as a break in oil. A Sweet spot oil is 15w-50 M1 @ 1200/1300 ppm P/Zn. Some advocate M1 V twin @1600/1750, The only reason not to is the cat and pocket book wear There are certainly other fine 15w-40 15w-50 oils out there that have specs similar to M1, examples are PennGrade 15w-40 @1500/1400(on the high side) Do you r due diligence, If the ZDDPs levels are specifically iterated they are likely too low. One last personal experience, a friend ruined his '93 964 after only a year or two of using Castrol 0w-50, it's unknown whether this was ZDDP or weight related |
I can tell you this..
Originally Posted by Bloose993TT
(Post 14802796)
