964 Forum 1989-1994
Horn button install help
Old 02-12-2018, 10:31 PM
Lorenzoh
Lorenzoh's Avatar
Default Horn button install help
89 With one wire coming from hub. Installed the Momo wheel and new Porsche horn button. I’ve checked that the copper contact on steering Column meets contact ring on new hub, plugged single wire into new horn button and seated button correctly. No horn. Checked horn fuse #3 and it’s fine.
Would appreciate any help. Could it be the relay?? Horn was working before removing OEM steering wheel.
TIA!
Old 02-13-2018, 12:15 AM
boostedt0y
boostedt0y's Avatar
TIA!
did you connect the horn hot wire from the clock spring to the L bracket that plugs into the steering column?
Old 02-13-2018, 12:53 AM
Lorenzoh
Lorenzoh's Avatar
first I’m hearing about this needing to be done. Would you mind elaborating?
Old 02-13-2018, 01:20 AM
boostedt0y
boostedt0y's Avatar
pm me your email address and I’ll send you instructions I used to do the install.
Old 02-13-2018, 06:43 PM
Foxman
Foxman's Avatar
Lorenzho, check out this thread for details: https://rennlist.com/forums/993-foru...ng-photos.html
Old 02-13-2018, 10:14 PM
kricci
kricci's Avatar
Think that is exactly the issue here. Had same thing on mine.
Quick Reply: Horn button install help
