9eleven headlights?
9eleven headlights?
I have seen adverts for what appears to be a HID headlight conversion that appears to fit right into the stock buckets. The ads say they come in two varieties, but nowhere on the website <https://9elevenheadlights.com/> does it make it clear what the differences are (rather than the name and the price). Has anyone seen or used them?
I have already put in a fair amount of effort into improving the 964's headlights by converting from H4 to H5 and re-wiring with relays switched by the dash **** to power the 100W bulbs direct from the battery (helps to have one's service dude be a smart guy with a degree in physics). I was less than pleased with the conversion kit, for the stock bucket is made from far better materials that the kit's bucket, and the adjustment then becomes quite fiddly.
Words of Wisdom, anyone?
Other than trim colours etc.. the difference is as follows?
The Raven is a bog standard (all be it very pretty bog standard) Bi-Led projector
The Raven S is as per above but also includes a DRL and turn signal.
Wish there was more information on these... there's been a lot of instagram hype but I'd love to see them compared to H5s, H4s, and H4s with 100w bulbs.
I don't drive much at night for long periods. Here are H1's on my C2
Confused you switched from H4's to H5's and not the other way around? You didn't see a considerable improvement over the H5's with the H4's? Honestly the H1's are so superior to both not sure why they don't get much love anymore and IMO look superior to all these new LED conversions which look odd to me and could never bring myself to installing on my cars. The H1's with a relay, 4 100 watt bulbs adjusted properly wired so both high and low bulbs come on throw more light than you would need but do draw power, heat and aren't as white but darn close enough and IMO look better. You can always convert to LED and still keep the classic look.
[snip]
[snip]
Unfortunately I bought a VW R-32, which has HID lights, and they're even better. The VW is my go-to-the-shops car, so it gets more use. I get hooked on better light out in front, and that's what led me to inquire about still further improvements, but improvements that don't screw up the car's appearance. A system that uses the stock buckets (which I retained) would be better than the conversion kit I used (which kit will be posted for sale when/if I make the swap back to the stock buckets).
The advice & comments received thus far = appreciated.
9eleven headlights?
Rationale? 100W bulbs make lots of heat. Both filaments on at once? More heat.
This is a 25-y-o car, and doesn't need more stress. You don't care? Your car, your choice.
I bought some, recently installed them and I love them. Simple install. I used my OEM trim rings although i understand i may have been the first person to do that.
The light out put is amazing - LED too not HID (if that matters to anyone). They put out the same or better light output than my 997 HID's...
Install was easy, and i love the DRL halos and the turn signals built in them.
No affiliation, just a very satisfied customer.
I have run the H1's setup with high and low on at the same time on high for decades from SC"s to 964's without issues. Power is drawn directly from the battery via a relay and heavy gauge wire with circuit breaker. They do get hot but so long as you are moving never has been an issue and I am not worried. LED is nice bright white light but don't project as well as the H1's on high. That is why most LED lights have projector HID bulbs for high and LED for low. I am considering H1 LED bulbs for the low beams and keeping the H1's on high.
cool - how much are these?
h4's with better bulbs/relays are excellent while preserving the oem look
francois at flat6 illum makes great lamps too, if u want the singer, new-on-old look
john audette also makes nice lamps, based on jw speakers
so many good options now for 964 headlamp upgrades
