shims, spacers and other belt removal issues - Rennlist - Porsche Discussion Forums
Go Back  Rennlist - Porsche Discussion Forums > Air/Oil Cooled Technical Discussion Areas > 964 Forum
Reload this Page > shims, spacers and other belt removal issues
Old 01-11-2018, 10:43 AM
5hrine
User
5hrine's Avatar
Default shims, spacers and other belt removal issues
New to 964 ownership and a few days ago one of the fan/alt belts broke, PO had assured me all belts had been changed. Finally all the parts arrived and I set about fixing the belts on the car, managed to undo the 24mm nut - no problem. came to remove the next bit (spacer?) seems as if it was welded to the alternator shaft along with a couple of mangled shims. Got the spacer and pulley halves off only to be faced with the next, almost welded on spacer. Anyone got any Ideas as to why they are stuck on, and any tips on how to remove. Also is the second inner spacer/shim on the right way round?
first stuck spacer and mangled shims
next bit of stuck spacer, is this the correct way round?
5hrine is offline
Old 01-11-2018, 12:11 PM
Rocket Rob
Rocket Rob's Avatar
Yes, the spacer is facing the correct direction. The wide part should support the back of the pulley half. This placement of the shims varies depending on how many are needed to get the belts tight. This is the default sequence and count. I normally end up with 3 shims under the alternator belt.
by the way, I would order a new set of shims. Yours are really mangled and you won't get the right shimming action from those.
https://rennlist.com/forums/964-foru...ley-shims.html
Rocket Rob is offline
Old 01-11-2018, 12:45 PM
5hrine
User
5hrine's Avatar
New shims are going to be ordered. Should there be a set of 6 shims in total (3 alternator with extra holes & 3 fan without extra holes) I am have been assuming that the alternator belt is the closest to the fan and the fan belt is the furthest away from the fan, is this correct?
5hrine is offline
Old 01-11-2018, 01:20 PM
Rocket Rob
Rocket Rob's Avatar
The pulley closest to the alternator drives the fan, the second pulley drives the alternator. If you have AC, you have a third pulley (furthest away).
Old 01-11-2018, 01:42 PM
5hrine
User
5hrine's Avatar
Okay, so the fan belt has the sensor.
5hrine is offline
Old 01-13-2018, 02:01 PM
HalV
HalV's Avatar
Correct! Also, make sure the studs for the fan belt are screwed in enough so they don't interfere with the spacer or the alternator pulley half. When I look at your second picture, the stud on the lower right looks like it could be out too far.
HalV is offline
Old 01-13-2018, 02:16 PM
5hrine
User
5hrine's Avatar
Thanks. I will check out the stud too. Just waiting for the parts to arrive. Got a battery drain to keep me busy in the mean time....and a water leak...and....
5hrine is offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright ę 1998 - 2017 Rennlist.com We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
Question Title:
