Xzn socket sizes
Xzn socket sizes
I'm going to pick up a set of Xzn sockets- what sizes should I get to cover all the fasteners on the 964?
Pete
Pete
Start with a full set of metric sockets/wrenches. I've only had my 964 for 7 months but have used everything from 8mm to 24mm on it so far. The most common size I have found is 13mm.
If you don’t want to spring for snap on I’ve found these to be quite good. Made in Taiwan. But Taiwan tools I’ve found excellent.
Technical Guru
I don't have the factory tool, so it's a bit hit and miss I expect. 10mm is too big, 8mm too small. I am just waiting to try a 9mm. If it's no good I will probably need to get the proper factory tool. Although I may try a Allen key to see how it works.
The newer Bosch alternators have about a 9mm fitting, while the original in my car was 10mm. I say "about" because I have multiple 9mm XZN drivers, and only half of them fit that shaft.
Sorry to hijack. Bought a new tool cart for a home box last week and it's had a cascading impact......
