My 964 - Page 20 - Rennlist - Porsche Discussion Forums
964 Forum
Sponsored By:
Sponsored By:
My 964
Old 08-04-2018, 07:51 AM
  #286
John McM
John McM's Avatar
Another point. Every thing you touch will be dirty. If that dirt gets into the oil lines it will go through the engine before being filtered, including the tiny holes that put oil on the tappets. Block one of those and you will be up for $$$$. Be very clinical about cleanliness.
John McM is online now
Old 08-04-2018, 08:16 AM
  #287
Dingo
Dingo's Avatar
Originally Posted by John McM View Post
Some books talk about crows foot spanners. I use normal 32mm and 36mm spanners. If you are lucky a gorilla hasn’t been in there before and they will come undone easily.
Btw: as you have signaled that funds are tight, I suggest that you stick to your plan or order only after you know the line is bad. There are a lot of smaller lines that could be the cause of your leak. Find the culprit before committing to $$$
Hi John, I'll get the wheel off tomorrow and have a good look. It would be nice if it was a cheaper one but I'm pretty sure it's seeping through
But Yes, Definately wanto be sure! I've been reading up all night on that particular hose and people have claimed a better quality getting their original hose rebuilt. I'll look into that if it's the culprit.
Glad to hear normal spammers can fit in there, can't afford to buy any more obscure tools yet haha
Dingo is offline
Old 08-04-2018, 08:20 AM
  #288
Dingo
Dingo's Avatar
That's a good point, I have things pretty clean underneath but I'll be sure to super clean everything and cover all the holes.
Dingo is offline
Old 08-04-2018, 12:23 PM
  #289
Marine Blue
Marine Blue's Avatar
Sounds like you need a degree in medicine to work on the engine based on above. But seriously it is very good to read and learn these things.
Marine Blue is online now
Old 08-04-2018, 09:18 PM
  #290
Dingo
Dingo's Avatar
Agreed! I take it all on board!
Dingo is offline
Old 08-04-2018, 09:21 PM
  #291
Dingo
Dingo's Avatar
Haha! Some serious cleaning to do Here!
Dingo is offline
Old 08-04-2018, 09:44 PM
  #292
John McM
John McM's Avatar
Given the relatively good protection in that area I’d say this has been leaking for quite some time. You may find that it’s seepage more than leakage. Fingers crossed.
Old 08-04-2018, 10:27 PM
  #293
Dingo
Dingo's Avatar
Dingo is offline
Old 08-04-2018, 10:30 PM
  #294
Dingo
Dingo's Avatar
Got it all cleaned up, about to go for a drive to see what happens! Hopefully it's just something easy!
Dingo is offline
Old 08-05-2018, 01:53 AM
  #295
Dingo
Dingo's Avatar
99% sure it's the thermostat to oil filter hose. Now I just have to work out how far I wanto go with it (do i replace everything) and whether I should buy new or get this one rebuilt.
I've read people have alot of trouble with new ones but have greater success getting them rebuilt.
Dingo is offline
Old 08-05-2018, 06:46 AM
  #296
Spokes
Spokes's Avatar
Nice cleanup and investigation work.
Spokes is offline
Old 08-05-2018, 07:00 AM
  #297
Dingo
Dingo's Avatar
Thanks mate! Was just reading about your wheel alignment. Awesome stuff!
Dingo is offline
Old 08-10-2018, 03:29 AM
  #298
Dingo
Dingo's Avatar
Big weekend coming up in the dingo shed!
Restoring the side sills to standard along with the front and rear bumpers.
And im all set for half an oil change!
I'll probably pull the oil tank and tidy it up. I'll also check all the oil hoses and replace if necessary.
Dingo is offline
Old 08-10-2018, 03:36 AM
  #299
Dingo
Dingo's Avatar
I had a bit of a practice at tightening the engine sump plug as I've never used a torque wrench before. 37 ft-lbs seems very tight, I've set the torque wrench correctly.
Dingo is offline
Old 08-10-2018, 04:02 AM
  #300
Spokes
Spokes's Avatar
D, post a pic of the torque wrench so we can see your setting. I would use NM not Ft-lbs. Metric system is so much more logical and German. I think that torque wrench has a flip side for NM.
Spokes is offline
Quick Reply: My 964
Contact Us About Us Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
