bored with the C2...considering small projects - input please
I've had my 94 C2 for a little over 2 years. I've pretty much left it alone with the exception of KW V3's, e88's, and a ducktail spoiler. I lose interest in cars when I'm not playing with them, so I'm thinking about a couple different minor garage projects. no real end "goal" here. The car will see light track duty, but not much as if I'm really going to drive something in anger it will be a race car, not a street car.
suspension - the car has more body roll than I like. So I'm likely adding sway bars. Looking at the new eibach ones. At the same time, I'll likely add adjustable end links. (any suggestions on cost effective ones? I'm shocked at how expensive they are compared to ones for more common cars.) Also considering the tarett rear spring plates. I am looking at them from the practical perspective that I do my own alignment, and getting rear toe and camber set right is next to impossible. Will I notice a difference when driving with these? (ie - is there a lot of deflection during compression that screws with the alignment while driving?) What else would you do under the car if you are on a budget? I didn't do adjustable upper mounts because I was able to get camber to what I thought was an acceptable setting - I might add a little more caster if I could, but not much.
interior - my 25 year old and 75,000 mi tan interior looks fine. but its boring. I'm considering adding a plaid insert to the seats and doing RS door cards in the same material. But don't like the look of the stock seats with inserts. What would you put in the car? Modern recaros? (I'm not super excited about a bucket in a car that sees mostly street driving - and I use the back seats for kids right now) Is there anything that provides a retro look without looking like I'm trying to put a 356 interior in a car from the 90's?
What other projects have you guys done that have increased your engagement with your cars?
Matt
Matt
GT3 player par excellence
bring it to bbi and thell them you want a Chris N car
or bring to Eli's guy and duplicate Eli car
done
done
yeah. ha. I'm looking for things I can do on jack stands in the garage and still send the kids to college. But I would be interested in driving yours. let me know next time its in SoCal. While I'm doing things under the car, any other suspension components short of front uprights that make a noticeable difference when changed? I've removed the 2nd muffler already. And I have a cat replacement pipe but I put the cat back on. Sounds like short of putting the car on a diet and focusing on weight removal, there isn't any one short coming on these cars?
Learn to drive it in anger on the track. You’ll have a whole another appreciation for the car
yeah. so brake pads and fluids and go put it on the track. Thats pretty much what I used to tell people on miata forums too. lol
Car needs a better alignment as well. then will go in december.
