Oil additives
Oil additives
hi!
has anyone ever used oil additives during oil changes in the 964 or 993?
i have a couple of bottles of Schaefer Moly E. P. that are supposed to “do wonders” (see link http://www.schaefferoil.com/documents/37-132-td.pdf ).
do you add anything to your oil or good oil is enough?
cheers
cheers
My thought on additives is there are a lot more well running engines on the road that never ran additional additives than those that did. It may not cause problems, and it may not 'do wonders'.
IHI KING!
I run just straight oil, no additives. I got 237K out of my engine before I rebuilt it. The valve guides were worn but the bearings and rings were in good shape.
Is there a specific problem or concern you are trying to fix?
Received 5,388 Likes
Use a quality full synthetic oil. Change every 5,000 miles, or at least yearly (for low use cars). You don't need additives.
Oil leaks !
Not really.
I just changed the oil with a Pennzoil 20W-50 (the cheapest) and I used the cheapest because... https://rennlist.com/forums/964-foru...l#post14616754
I think it's still a good oil. I just happened to have a bottle of this treatment that I used once on the NSX and I was wondering if I should throw it away or try it .
Not really.
IHI KING!
Have you read any of the threads on Bob the Oil Guy? They have discussions about Schaefer Moly EP
https://www.bobistheoilguy.com/forum...Number=1726384
I use good oil, but I like to add "vitamins" and change it often...
I've been using Brad Penn 20/50 for years, but a recent service garage change means I'm using Motul 15/50 V300 now.
I then add a can of Liqui Moly MoS2 Anti-Friction Engine Treatment after my engine burns through a 1/2 quart of oil: https://products.liqui-moly.us/addit...treatment.html
I do a complete oil change after 3,000 miles.
A couple tanks before I'm due to change the oil again, I add Liqui Moly Valve Cleaner OR Liqui Moly Jectron Fuel Injection Cleaner to the gas tank: https://products.liqui-moly.us/addit...ct-media-modal
All I understood is that there are oil additives type of guys and just straight oil type of guys
RL Technical Advisor
No oil additives for me.
I use a good oil that contains what I need since additives require different chemistries to balance the effects of such things.
