Tracking down gas smell -- where does this expansion tank hose go?
I'm trying to track down a slight gas smell in my '90 C2. I've checked the typical problem areas and it seems like the smell is coming from my shut-off valve (item 10, green arrow in first picture).
Before I replace it, I want to find out where the "connecting hose" (item 4, red arrows) goes to on the other (bottom) end. Does anyone know?
Thanks,
John
Thanks,
John
I had the same smell and traced it to same location. But it seemed to me the problem was that the hose (4) had shrunk and was pulling the valve (10) out of the gasket. I loosened the clamp and got some slack so I could seat the valve. No smell after that adjustment.
Would still like to know where hose goes in case it has to be replaced.
I replaced the valve, and still have the gas smell. Will change out the fuel filler neck next - it has been revised umpteen times for reasons, I'd imagine.
If you only smell it after you've been driving the car I'd check the line on the right hand side front of the engine compartment that comes from under the car to the motor. It's solid up until the engine compartment and then it turns into rubber. It took me a long time to find that on mine and when we finally checked that it burst when we grabbed it.
My shop informs me since mine they've found 5 other cars with the exact same issue.
I'm having the same issue with my 964 after it has been sitting for a few days. Could that line vent fumes out the underside of the car? Wondering if it could be clogged?
I also detected the smell of gas from under the frunk. Porsches are meant to smell like leather and gas, but this was a bit over the top. A quick examination under the frunk revealed that the vent line shut off valve had snapped off and was venting freely. Add that to the list of many items missed on my PPI.
A little Oatey's plastic cement seemed to do the trick. No more smell of gas.
Here is the hose I believe you are describing:
You can see the new fuel injection hose clamps on my car from a previous replacement of that hose. It is originally crimped on the hard line.
I replaced that hose again while I had the engine out, this time using Cohline 2240 hose. Be careful that the new hose clamps are not chaffing any of the neighboring lines.
I borrowed this pic from Pelican , hope that's ok. I believe this is the roll over shut off valve - can anyone confirm - on my car, I can move this valve just a bit. It wiggles to light pressure, I can't take it out but it does move a few mm's to each side. I would assume this is not the way it is supposed to be? Does anyone know how I can "tigthen" it? I already have a new fuel neck on its way ( I have the old version and assumed this is the issue ) but as I read on, perhaps this valve is the problem.
I am not up for moving the gas tank so if it's complex, to the shop she goes. Thank you.
Thanks Deserion. I can pull up on that valve and it will rise about 1/4" which was surprising since everything else is so damn bolted down. Glad to know a bit of wiggle is ok and I assume, not the cause of smell of fumes in the frunk and cabin. I just replaced the filler neck ( it took my longer than 15 min !) and I hope this helps. I believe the HVAC fans pull air from the frunk and send it into the cabin. I think the fumes are originating in the frunk and HVAC fans are bringing it into cabin. The fan on my 91 C4 is always "on". Even when fan speed is set to "0", it always runs just a bit. That's another topic altogether as I know many fans shut completely off but some stay on just a bit all the time, like mine. I think its contributing to fumes in cabin. Anyone experience this too?
