Wheel spacer size
Wheel spacer size
First off thanks any advice.
I have a suspension off a Euro RS on my car, so obviously it's at RS ride height. Question is, there's no spacers on the car and to me the wheels are a bit to far inset. Does anyone have a similar setup that can recommend a spacer size. I was thinking something mild like 5 or 7mm would do the trick for a good look. Any advice is appreciated. Thanks!
My car was RS height with D90s. I used 5mm in front and 21mm in rear. Looked great no rubbing.
I changed wheels and have zero spacers in front while using the 5 mm in rear.
21mm are for sale.
21mm are for sale.
Changing studs is correct. On my 21mm spacers the spacers had studs pressed into them. Bolt spacer to car bolt wheels to spacers.
I have a friend with 93 964 and Cup 1 wheels. 15mm spacers and new studs front and rear.
Same Suspension with MM cup1 Wheels. In the rear i have 15mm. Front was 5mm but with negative effects to the handling. I removed the front spacers therefore...
