Billet 25mm Porsche spacer CLEARANCE!
Former Vendor
Spacers
Our spacers, which are offered in
"1" are made of
T-7075 aircraft aluminum. This is much stronger aluminum, and our design makes them lighter than the rest. The competition uses T-6061 aluminum(if made in the USA and not China), which is a fine aluminum, however, ours are better. Our billet aluminum spacers are CNC machined & hub centric. Also, our spacers come with lug nuts and OEM sized 14mm studs built into the spacer for an easy installation using your OEM lug nuts on them.
25mm("1" )spacer= $ 69.00 a pair plus 11.00 dlls shipping in continental USA
"1" are made of
Spacers
"1" are made of
"1" are made of
Best luck with your venture if you made different sizes I would be interested in what you come up with.
