Floorboard DIY
A while ago I did a temporary fix on the driver's footwell when I found the wet, rotten soundproofing under the carpet, by filling it with some light weight foam and putting a board on top. Last summer I finally got round to doing a proper job by making some wooden floorboards like those found in the cup cars. So, following a request I received from another Rennlister, I thought I would write up my DIY.
First job was to get the seats out, remove the carpet and everything else in the foot wells. I could then get to work on making a template from cardboard before breaking out the jigsaw on some 6 mm plywood. That was followed by a good coating of yacht varnish: http://i32.photobucket.com/albums/d2...y/SDC11109.jpg Here's a piece of the old soundproofing next to one of the new floorboards. The sound proofing pieces weighed 3.5 Kg each and the replacement boards just 2 Kg each: http://i32.photobucket.com/albums/d2...y/SDC11113.jpg Whilst the boards would be screwed onto the raised beams in the footwell, they also needed to have a support in the deep part. So I came up with a door stop, some repair washers as spacers and bolted these to the boards using one of those two piece bolts that are used to join kitchen units together: http://i32.photobucket.com/albums/d2...y/SDC11111.jpg http://i32.photobucket.com/albums/d2...y/SDC11119.jpg To fit the boards I simply unscrewed the press stud (you can see it just forward of the seat) and then drilled another hole in that same floor beam nearer the pedal box. Then I just used a couple of self-tapping screws and washers to fix the boards in place. Nb. The door stop was located on each board so that it settled on the slightly raised part of the floor (again see pic below). http://i32.photobucket.com/albums/d2...y/P2221170.jpg Passenger floor board fitted: http://i32.photobucket.com/albums/d2...y/SDC11120.jpg Driver's side: http://i32.photobucket.com/albums/d2...y/SDC11123.jpg Here's my new co-driver checking out one of the seats while it was out of the car :) http://i32.photobucket.com/albums/d2...y/SDC11118.jpg Of course, it's possible to buy even lighter ready made floor boards (Rennline make them) but since they're optimized for LHD cars, I wasn't sure if they would fit my RHD car. Besides which, the total cost of making my own was less than 20 quid. :cheers: |
Absoulutely brilliant Steve. Thanks for posting this.
I hadn't though about using wood. I was considering getting some aluminum sheet cut to size, then fettling it to fit. But this - this is a much more economical and dare I say, authentic solution. I like having a little Cup Car in my C4. Cheers, Cliff |
Originally Posted by The Stig
(Post 8230402)
I hadn't though about using wood. I was considering getting some aluminum sheet cut to size, then fettling it to fit. But this - this is a much more economical and dare I say, authentic solution. I like having a Cup Car in my C4. Cheers, Cliff |
If one was to use alumimum, how thick should it be? 6mm would be too thick and heavy, wouldn't it?
(Post 8230779)
