Tie Rod Removal/Steering Stop Install
1 Attachment(s)
After I increased the size of my front tires recently I encountered a problem with tire/wheelhouse rubbing when turning. A little research turned up an improved steering stop from Porsche to address the problem. The enhanced stop is thicker (10 mm vs. the O.E. 6 mm stop). Installing the stops involved the removal/re-installation of the tie rods.
The improved stop is on the right: |
1 Attachment(s)
Here is the procedure I used:
Tools required: Open end wrenches 32mm, 22mm, 19mm, 15mm Socket wrench and 12mm socket Torque wrench Ball joint press Bentley manual (optional) Brass mallet (tool of mayhem and destruction) Scale |
1 Attachment(s)
Jack the front of the car and support it safely with garage stands.
Remove the front wheels. Spray the tie rod jam nuts and ball joint nuts with PB Blaster or Kroil (my favorite). Go make and drink some coffee while the penetrant soaks in. Measure the tie rod length with the scale. I measured the distance between the two chamfers at either end of the rod. This will help you during installation so you can drive your car to the alignment shop when you are done. Go back into the garage and remove the 12 mm lock nut from the tie rod end ball joint. |
1 Attachment(s)
Loosen the tie rod jam nuts (this will aid in freeing the ball joint from the steering arm and it's easy to do at this stage).
Put the ball joint press on the steering arm. Get the ball on the press rod into the recess on the bottom of the stud. When everything is seated and secure use the 19mm wrench to turn the rod and press the ball joint out of the steering arm. |
1 Attachment(s)
It's important to resist the temptation bang on the stud with a mallet; damage the stud end and it will be very difficult to remove it.
Ok, now lift the ball joint stud out of the steering arm toward the rear of the car, rotating the ball joint as you do so. Otherwise the coilover will interfere and prevent the removal. Once the ball joint is free, take it off completely. This will make removing the tie rod from the rack rod easier. Now go to the rack and pull the gaiter back. You will now see the steering stop. |
1 Attachment(s)
If you start on the left side of the car, turn the steering wheel to the right, full lock (I ended up tying the wheel to the door handle to hold it over). This will give you room to do this next step.
The steering stop is onto the tie rod end and tightened onto the rack rod. To break it loose counterhold the rod with the 19mm wrench and turn the steering stop counterclockwise with the 32mm wrench. |
1 Attachment(s)
Once the tie rod is loose, turn it counterclockwise until you can remove it. It's easier to remove with the ball joint off.
Now, install the new, improved steering stop. The Bentley manual says that a gap of 4 to 5mm must be set between the stop and the shoulder of the yoke. You can see it here. Depending on which side you are looking at, there will be between 1-2 threads showing at that gap. This is important to know as you will have to turn the stop to tighten tire rod to the rack rod and this will let you estimate the proper gap. You could make yourself a feeler gauge out of cardboard if you don't want to eyeball the gap. |
1 Attachment(s)
Now, thread the tie rod back into the rack rod. Set the gap and tighten the stop against the rack rod counter holding the rack rod with the 19mm wrench and turning the stop with the 32mm wrench (reverse of removal). Make sure when you have it tight (70 N-m) that the yoke is perfectly horizontal to the road.
Thread the ball joint back into the tie rod. Swivel the ball joint around and put it back into the steering arm. Thread the 12 mm lock nut back on. As you turn the nut the ball joint will rotate too so take a wrench and wedge it between the top of the ball joint and the bottom of the coilover. Torque to 65 N-m. |
Adjust the tire rod length to the value that you measured before you removed the tie rod (remember that the jam nut closest to the steering rack is a left hand thread). Tighten up the jam nuts. Now you are ready to tackle the other side.
When you are all done, reward yourself with your favorite adult beverage as you just saved yourself 2 hours of Porsche shop time ($100/hr here in Michigan). You can now re-set the toe yourself (strings and jackstands method) or take you car to a good alignment shop that works on Porsches and other exotics. |
