How to replace window seals
Hi again Ed,
As promised here are a couple of pics that show (in order of appearance) how you can change the rubber seals between the door and window.
The metal rail that holds the seals in place is held to the door by metal clips.
1. Gently wedge a screwdriver between door and rail to losen the rear end of the rail.
2. Slide out old seal.
3. Slide in new seal.
4. Snap rail back in place.
And you're done!
And you're done!
