complete brake replacement
if I wanted to completely start over with the brakes on my car and wanted to replace everything with a modern 6pot willwood or stoptech system with dual master cylinders, is there anything out there that is already figured out? or would it all be custom fab work.
I'm hoping I could get a parts list
Rainman
Hi,
Call these guys, they make brackets to adapt Wilwoods to the 944 front and rear.
944T rear caliper mount lugs are the same spacing as 944NA so the bracket from this kit should work for you.
The intended Wilwoods are about $120/caliper last I checked and come in a variety of bore sizes.
http://www.wagenswest.com/partstore/...ustom-oem.html
