FS - Spring/Summer Cleaning
A few projects changed direction resulting in a few good parts on the shelf.
Prices are reduced for quick sale. All sales are final, prices do not include shipping or PP fees.
First to pay gets the part! Local pickup on heavy items is preferred.
- 968 3L crank - USED, spun rod bearing, good for a hybrid stroker - $475
- ROSS 3L turbo pistons -NEW, for sleeved engines (not Alusil) 104mm, 88mm stroke,8:1 CR, rings included.. - $550
- Wossner 2.5l 944S 2.5L turbo pistons - NEW, alusil compatible, 8:1CR, rings included.. - $700
- Complete 944S 16V engine - USED, good cylinder walls, taken apart for inspection, needs to be reassembled. - $1100 (local pickup only, available once the Wossner pistons sell).
- 944S engine + Wossner tubo pistons, your base for a 16V turbo engine - if purchased together - $1600 (local pickup only)
- 951 block sleeved - 104mm - Aluminum around one of the sleeves has a crack. Engine was getting prepped for high HP application. Some work is needed, the blank sleeves were $500 not including the machine work - Fix it, remove the sleeves, or ?? - First $200 takes it - (local pickup only)
More items to be added...
If seriously interested, email me directly.
