Oil question for my 951
What oil do you guys use on your 951's?
Im doing some trackdays, with a bigger oil cooler, so i dont think oil temp will go above 110 c ( Metric )
Engine will make aprox 400-430 bhp.
Im thinking of Gulf Racing 5w-50.
What do you use?
Thanks.
Erik
What do you use?
Thanks.
Erik
Joe Gibbs breakin
Joe Gibbs 15W50 XP4
then once broken in....
Millers 20W50 nano
These oils have high ZDDP levels just to add
Joe Gibbs 15W50 XP4
Millers 20W50 nano
Do not use 5w-50 in a 951 at the track , you're oil pressure ( hot ) will be too low & the risk of insufficient oil pressure to no 2 con-rod bearing
Minimum oil viscosity at the track is a 20w-50 & I mean minimum
On that subject , how old are the con-rods in the engine & age of the con-rod ( big-ends) bearings ?
The reason I asked is }
A) old con-rods metal fatigue
B ) old con-rod bearings that are 25 years old and are already badly worn & No oil will save that engine on the track
I ran Redline 5W-50 in my NA for a while. I remember comparing the viscosity levels between it and similar XW-50 oils and it was significantly thicker at 100 deg C. These figures are of course published in the oil datasheets which are online generally. So for a track car, Redline 5W-50 may actually be a better choice than a typical 15W-50 or something. For most of us, they're all fine, just depends on local availability and price.
With a workshop oil pressure gauge connected on a last century Porsche & at 95 deg cel oil temp , every 5w-50 we have tested in the last 15+ years reads a lower oil pressure than a 20w-50 ( same brand )
You're average 5w-50 is more like a 7.5w-43 oil viscosity ( the numbers on the bottle "5w-50" are just rounded off )
You're average 20w-50 is more like a 20w-48 oil viscosity , a 20w-50 at high oil temp will always give better oil pressure
A typical 5w-50 is really just a 5w-40 with more Vii's ( viscosity index improver's )
For a deep last century Porsche engine you must keep the oil pressure up when oil temp is above 100 deg cel
For one of our own or a customers 951 that's to be used on the track , I would only allow a 5w-50 to be used in the car park only
I have a recent rebuild and I am running natural oil through it now as I am changing it out every couple of outings. I will switch to synthetic some time later this year.
Rainman
That's interesting, thanks for sharing your results.
I'd like to go to my auto store and ask for 7.5W43 oil now..
Then again I could be mistaken and he is really from Alice Springs I which case he would be nuts for not using a high W number.
It has 160 000 km on it's back.
Since i deal Gulf Oil where i work, im going to use that.
In Considering 15w-50
http://www.opieoils.co.uk/pdfs/gulf-...data-sheet.pdf
Erik , I take it that it has 160,000kms ( 100,000miles ) , do you mean the con rods & the con-rod bearings are that old , with the extra HP that it now has ?
