Ealokens Porshe 951
#226
But it now rest`s in my office with all the other porsche parts.
Engine building in januar i think.
#227
Good luck, should be quite a beast. I have to get my sh*t together and do something soon too.
#228
You'll need to turn boost up to eleven to hit 500whp on 2.5 8v.
#230
Judging by bulds that were completed over the years here, that is very optimistic. Your builder better have experience with tuning 951 because it just won't handle boost as good as some other cars.
https://rennlist.com/forums/944-turb...running-9.html
This is a good example of 8v build but it's 3L.
#232
My head flows 30% more vs standar.
New camshaft and Intercooler that suports the flow.
February / March wil show
#233
Careful. Germans would say: Besser ein Spatz in der Hand als die Taube auf dem Dach
#235
Increasing overlap and trying to fill the resulting "compression leak" with an oversized turbo running lots of boost will be inefficient at best, and the engine will run quite bad at worst. Been there, done that. I ran a high duration camshaft up to 2.2 bar of boost with a GTX3076R without getting knock yet the car was slower than with the stock cam at 1.2 bar of boost. The engine was just an inefficient heat pump. Only interesting detail I remember was popping out a valve stem seal or two because of the high boost.
#236
Increasing overlap and trying to fill the resulting "compression leak" with an oversized turbo running lots of boost will be inefficient at best, and the engine will run quite bad at worst. Been there, done that. I ran a high duration camshaft up to 2.2 bar of boost with a GTX3076R without getting knock yet the engine was slower than with the stock cam at 1.2 bar of boost. The engine was just an inefficient heat pump. Only interesting detail I remember was popping out a valve stem seal or two because of the high boost.
My engine builder has built a lot of engines, and he calculates the engine before we dyno, and with that we know what it will make.
My biggest conserne is all the doubters.
Back in the day i had a 2.5l Volvo 4 syl it made 500 bhp on E85 and 1 bar boost.
#240
