Cruise control malfunction
When I try to set the cruise control it puts it into acceleration mode. I am sure someone here has run across this problem, any help appreciated.
After doing more research I think I will disassemble and clean the cruise control servo. I got the idea from Clark's garage and seems to line up with my vehicles symptoms.
My clutch doesn't pop up to the full "up" position by itself - it needs a little help. If I forget and try to engage cruise when the clutch is not all the up, it's starts accelerating. Might check the switch on the clutch pedal, or make sure your clutch is engaging the switch.
You may want to investigate the capacitors in the cruise control brain.
Here is a thread that has some info.
https://rennlist.com/forums/944-turb...cheap-fix.html
I have done nothing with the cruise control to date, but was able to take the vehicle on a 500 mile round trip long weekend into northern Michigan. On the way up the cruise control worked flawlessly and was nice to have. On the way down in was completely unresponsive. Go figure.
Failure to engage, unintended acceleration and failure to hold set speed are fairly common problems that can be a result of cracked solder joints. Remove CC control box, open and look for cracked solder joints. Reflow the joints and you may fix your problem. Flaky DME performance can also be from cracked solder joints.
If it worked for half your trip I would suspect the CC brain and not the servo. As mentioned above, check he solder joints, while you are in there might as well replace the capacitors.
I had intermittent issues and nothing worked including reflowing all solder joints, except replacing the caps. It's only a few dollars and takes very little time once the brain is opened up.
Guys - will do i will take out the CC computer box in the footwell. If i take out the CC box will it impact any other electrical devices or is it a closed loop? I.e. can I drive the car while I am repairing the CC box?
