Has anyone tapped the exhaust header flanges?
...to make R&R less of a hassle. I did mine for the first time a few weeks ago, and was having a hell of a time getting those 6 nuts/bolts off. I remember 4 went smoothly, 1 was annoying, and 1 was REALLY annoying. I was thinking, what about tapping the flanges so you don't need to have a wrench/socket on each side of the connection. Or maybe I'm just missing the magic touch. Is tapping them asking for trouble when it comes to integrity?
Professional Hoon
Here's what I think,
Good:
Easier to do up.
Bad:
More of a chance the bolts can seize up.
Which leads to them breaking.
A chance of it rattling off.
You could use ani-seize paste. stuff usually works well. But them falling off is the problem.
Good:
Easier to do up.
Bad:
Thanks for the reply. I use anti-seize on almost everything, but yeah you're right about them wiggling loose. Moreso than a nut though? I suppose the nut has the advantage of friction acting against the bottom face.
I suppose it would also reduce the amount by which the flanges could move under thermal expansion somewhat. If you try it, I might be inclined to tack weld nuts onto the flange rather than try to tap those old crusty flanges.
I assume you mean the flanges where the x-over pipe bolts up to. Seems like you'd have to enlarge the corresponding hole in the non-tapped flange to accommodate the studs which might result in reduced area for landing the washers/nuts?
What about just welding the bolt in from the top side of the flanges?
Hmm, I like the idea of welding in the bolts to create studs. That opens up the option to use locknuts from below (not nylon obviously). Only concern would be, if I'm actually making it harder to R&R, because now I have to line up 3 studs at once when fitting the crossover or header section. Probably won't be that bad, I just know how big of a bitch that can be.
