DME Temp sensor
It could theoretically. With the car sitting at atmospheric temp, what's the resistance across the 2 pins? That should be all the info you need to see if it gives the dme a real reading during cranking.
I got to check that . I got a no start condition after replacing the vacuum lines. I have done everything I know and still can't figure it out. I got a feeling it's the DME.
Yes, I also checked all the sensors with the voltage meter. re-took off the intake checked all vacuum lines. Check spark, the only thing I'm waiting on now is a fuel pressure gauge to check presser. I pulled the fuel bar and tested it, they all fired. Guys, I've been working on 944s for 20 years, I never been this stump before. If it's not fuel pressure then is definitely going to be the Dme I guess.
While waiting on your fuel gauge you could pull your dme sensor and jump 30/87b and you should at least hear your fuel pump running (if not, case closed). There is also the old corner case on clark's about too much pressure on the rail (which causes no start) - you can check by pulling one of the injector wires and see if then it starts. Anyway, couple ideas while you wait on the gauge.
I jumped it, it turn the fuel pump on. It sounds like it wants to start, like a starved for fuel. Even though I'm getting fuel coming out injectors I'm wondering if the pressure is low.
Go back to your last changes. Check to ensure all the vac lines are attached to their proper points, and that they're still attached...
I remove the intake and checked all lines. I ordered a fuel filter with the pressure gauge I'll change that out.
Keep coming with any suggestions, hopefully overlook something.
